HF pocket hole jig modification - Router Forums
 7Likes
post #1 of 13 (permalink) Old 08-21-2016, 11:25 AM Thread Starter
First Name: Ken
Default HF pocket hole jig modification
When I considered buying a ph jig I took a look at the Kreg and Harbor Freight jigs. I really didn't want to pay a lot of money for blue plastic, and the reviews on the HF jig were mostly very positive so I went that route.
Using it, I quickly discovered why many of the reviews mentioned the lack of dust collection capability as a negative, so I thought about it and came up with a mod.
As my jig is bench mounted I made a spacer under it that that has intersecting 1.5 inch holes at 90 degrees to each other. My spacer is not pretty, it was material I had at hand, and because this was an experiment I wasn't concerned with looks. One of the holes lines up with a hole I made in the base of the jig. I pushed my vac hose in the other and tried it. It works great and I have much less of a problem with chips needing to be cleared.
Not in these pictures is that I wrapped the seam between the spacer and the jog with some tape to seal it up. I also put tape on the vac hose before pushing it in the hole.
Now that I know it works I think I'll make a spacer out of wood. It'll be better looking, and give a smoother air flow.
kklowell is offline
post #2 of 13 (permalink) Old 08-21-2016, 12:04 PM
bryansong's Avatar
First Name: bryan
Ken, that looks like a great idea. Nice work!
Bryan
bryansong is online now
post #3 of 13 (permalink) Old 08-21-2016, 12:15 PM
Good idea Ken and the only person who needs to worry about how it looks is you.
post #4 of 13 (permalink) Old 08-21-2016, 12:42 PM Thread Starter
First Name: Ken
Well, yeah, but I'd rather it looked a bit nicer. Vain I guess. LOL
kklowell is offline
post #5 of 13 (permalink) Old 08-21-2016, 05:57 PM
MT Stringer's Avatar
Hmmm...Ok Ken, don't stop now. You have a good platform for the MikeyDoodleThingamajig!
http://www.routerforums.com/jigs-fix...-hole-jig.html
Herb Stoops likes this.
MT Stringer is offline
post #6 of 13 (permalink) Old 08-21-2016, 06:19 PM
RainMan 2.0's Avatar
Nice setup Ken . I'm liking that jig far better than my plasticy think from Kreg .
I'm with you on the DC , as I had a frigging mess when I was done
Ok ,I never insulate
RainMan 2.0 is online now
post #7 of 13 (permalink) Old 08-21-2016, 06:22 PM
old55's Avatar
First Name: Ross
Good one Ken.
Ross,
old55 is offline
post #8 of 13 (permalink) Old 04-18-2018, 11:54 AM
Hi, has anyone had problems with the drill bit binding up in the bushing? This happened to me after many hours of use and I don't know what caused it. Could the drill bit have expanded from heat? Maybe there is a coating on the bit that wore off? Anyway, the bushing is now bad and I need a replacement. Anyone know where to find replacement bushings for this pocket hole jig (made by Drill Master, sold at Harbor Freight)?
tacarlso is offline
post #9 of 13 (permalink) Old 04-18-2018, 12:09 PM
Nickp's Avatar
First Name: Nick
Not sure what you are using the jig on but if it's wet or sappy wood, pitch builds up on the bit and the inside of the bushing and then messes up the bushing...use a bit cleaner like CMT or Trend after using (or during, in your case) to keep it clean.
Don't know where to get replacements...I imagine they might not be quality steel...
Good luck...and welcome to the forum, if you're here to stay...
Nick
Points to Ponder...
LEARNING - the decision you make to know and
understand more about some thing.
TIME - the thing that gets in the way of learning.
Nickp is offline
post #10 of 13 (permalink) Old 04-18-2018, 02:23 PM
Lee Valley sells drill bushings. I also have a doweling jig of this type: https://www.amazon.com/Woodstock-D41...s=doweling+jig The diameter and thread pitch is the same on them but I had to thread the hole deeper on the jig so that I could use the LV ones I have. They are both 1/2" diameter by 20 threads per inch (SAE fine thread). I don`t know if that is standard or not but there is a pretty decent chance that it is. A caliper and thread gauge will tell you or if you a have a 1/2" fine thread nut that will tell you too.
Pocket Hole jig made from scrap Carpenter12 Jigs and Fixtures 10 02-07-2015 05:33 PM
My First Jig Coleve Show N' Tell 14 03-10-2013 09:12 PM
Pocket Hole jig istracpsboss Tools and Woodworking 21 03-26-2010 11:27 AM
Hinge mortising question Dalec Jigs and Fixtures 8 03-02-2009 07:17 AM
Pocket hole jig hawker44 Jigs and Fixtures 6 10-23-2005 11:19 AM
