Water Damaged oak cabinet doors - Router Forums
post #1 of 21 (permalink) Old 11-15-2008, 11:20 PM Thread Starter
joeboxer's Avatar
First Name: Joe
Default Water Damaged oak cabinet doors
After many years of neglect, and not having had much time to tend to the issue, my oak kitchen cabinet door has separated, and some black mold has made themselves at home.
This is the worst one of the 2 doors that sits under the sink. This isn't from a leak, or flood, its just water splashes here and there, that caught and collected in the groove of the lower rail. I suspect the biscuit is swollen up.
Any way to disassemble this thing, and repair it?
The rail/frame is impossible to find, and make.
I'm all ears, and hoping for suggestion on how to go about repairing this.
Would soaking it, or blasting it with hot steam help to unbond the glue?
Soak it in the bath tube with something?
For the mold ... Bleach or TPS? What's TPS?
My opinion; worth price paid
Current Router: Triton 2 1/4, great multi purpose router.
joeboxer is offline
post #2 of 21 (permalink) Old 11-16-2008, 12:01 AM
Hamlin's Avatar
First Name: Ken
Hi,
Not sure adding more moisture is going to help. I personally like to use a heat gun to break glue free. A hair dryer would work too. Just keep the heat moving. don't keep it in one spot. If you have a "cat's paw", small pry bar, use it in conjunction with the heat.
For the mold, use bleach. I'm sure others will chime in on this part.
Ken
"A VETERAN"
Hamlin is offline
post #3 of 21 (permalink) Old 11-16-2008, 02:17 AM
curiousgeorge's Avatar
First Name: George
Joe, I think you are going to have a hard time getting those doors apart. Most cabinet makers use nails as well as glue. I replaced some oak cabinet doors for my daughter. When I tried to take them apart to salvage the oak, I ended up having to saw them up and that is when I discovered the nails. You might end up having to build new doors. In fact that might be the easiest solution.
If you can get rid of the mold, maybe you can just re-glue and clamp the doors back together.
George
Fort Worth, Texas
City where the west begins.
curiousgeorge is offline
post #4 of 21 (permalink) Old 11-16-2008, 06:37 AM Thread Starter
joeboxer's Avatar
First Name: Joe
I've swept the area with a neodymium magnet, and there doesn't see to be any pin nail there holding the panel in place. I couldn't see any sign of a pin nail head, or filler putty pin points to indicate a pin nail.
Fingers cross.... I don't mind rebuilding the thing if I had the right profile bit available, however, there just isn't. I went to Lee Valley Tools up here to check for a bit that might do the trick, but alas, no luck.
Heat gun!!!! I think that makes perfect sense ..... THANK YOU!!!! I'll try that out.
joeboxer is offline
post #5 of 21 (permalink) Old 11-16-2008, 07:50 AM Thread Starter
joeboxer's Avatar
First Name: Joe
Ok, no nail, but the glue used on the lower rail did hold on to the lips on some of the lower rails, and was hence ripped off. No biggie ... Glue destroyith, Glue Repairith ...
But good god, I have a mold bank in the grove where the panel goes at the bottom due to the air pocket there.
Time to take this work out doors, mask, and wet sand ... no machine for me....
joeboxer is offline
post #6 of 21 (permalink) Old 11-16-2008, 09:21 AM
Hi Joeboxer
Looks like fire wood, keep the panel and make a new frame
Think mold,it's hard to get it out of wood...
Mitered Door Frame plus how to do video
http://www.mlcswoodworking.com/shops...r_video_anchor
post #7 of 21 (permalink) Old 11-16-2008, 12:01 PM Thread Starter
joeboxer's Avatar
First Name: Joe
Bob, no matter how sensible or logical your advice is.... la la la la la ...... I'm not listenning ... la la la la!!!!
:P Three letters ... R ... O ... T ....
There is rot in the rail ....
And the part of the panel that was sticking into the bottom frame grove is rotted pretty bad, so that might not be salvageable unless ....
I'm thinking, CPES or Minwax wood hardener. I can use some to repair my catamaran this spring. The plywood deck has delaminate enough to let some water into one of the hull.
I'd love to start making door panels and rails ... but the previous home owner didn't have the foresight to leave behind the matching frame profile router bit.
The video was excellent - The profile is close ... maybe if I look harder, I can find my profile. Profile on the video #8781 is extremely close, except mine is an elongated version, which is 3" wide. The one there is 2.5"
This is one frame profile I did not see at my local lee valley tools retailer.
I might as well watch the video over and over again ... .... I have this gut feeling that I'll need to memorize it.
joeboxer is offline
post #8 of 21 (permalink) Old 11-16-2008, 12:26 PM Thread Starter
joeboxer's Avatar
First Name: Joe
And here are some pictures ...
Image IMG_4223 was before I started scraping the mold off. The edge started crumbling when I put the chisel to it.
joeboxer is offline
post #9 of 21 (permalink) Old 11-16-2008, 12:55 PM
Hamlin's Avatar
First Name: Ken
Hi Joe,
Unless I'm looking at the wrong profile, this looks close to what you have.
http://pricecutter.com/medium-panel-raisers/p/P15-3906/
http://pricecutter.com/large-panel-raisers/p/P15-3918/
Ken
"A VETERAN"
Hamlin is offline
post #10 of 21 (permalink) Old 11-16-2008, 03:21 PM Thread Starter
joeboxer's Avatar
First Name: Joe
Originally Posted by Hamlin View Post
Hi Joe,
I've not looked at the panel profile yet. But thanks for the head start.
The profile I'm concerned with is the frame/rail profile
joeboxer is offline
  LinkBacks (?)
LinkBack to this Thread: https://www.routerforums.com/joeboxers-gallery/10343-water-damaged-oak-cabinet-doors.html
Posted By For Type Date
Water Damaged oak cabinet doors Post #0 Refback 12-21-2010 03:41 PM
Water Damaged oak cabinet doors - Canadian Woodworking Forum Post #0 Refback 04-05-2009 10:05 PM
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 32 03-24-2013 03:26 PM
arched rail cabinet doors jimf New Member Introductions 6 01-27-2009 03:31 PM
Oak draw fronts and cabinet doors vapochilled Show N' Tell 12 01-17-2008 01:06 PM
Faux Cabinet Doors WoodyRon Tools and Woodworking 2 08-03-2007 06:56 PM
kitchen cabinet doors help puretrick Tools and Woodworking 15 06-05-2005 04:28 PM
