six sided box - Router Forums
post #1 of 7 (permalink) Old 03-30-2009, 08:07 PM Thread Starter
boxman01's Avatar
First Name: john
Smile six sided box
This box started out to be a 3 sided box I soon found out that when i set my saw at what i thought was a 30 degree cut was in effect a 60 degree angle, but anyway a box was made, i had put a inlay strip on the zebrawood before the box was put together,& i had some maple to make the sides, for the top i used maple burl & put brass pin hinges on the back, the finish was shellac on the inside & a wipe-on poly for the outside.I guess i'll have to make a jig to cut a 30 degree angle for the 3 sided box !
boxman01 is offline
post #2 of 7 (permalink) Old 03-30-2009, 09:01 PM
Hi John
Very nice box ,, here's a way to cut a 3 side box it's tricky, but not to bad on the chop saw,,,the key is to make one cut on a 3" x 3" x 8" block and then clamp it in the chop and then use the block to cut the rest of the parts for the box.. see link below ..
http://www.routerforums.com/project-...eeds-help.html
post #3 of 7 (permalink) Old 03-30-2009, 09:34 PM
Bob N's Avatar
First Name: Bob
John,
I think that is one error that worked in your favor.
Great Box!
Bob N is offline
post #4 of 7 (permalink) Old 03-31-2009, 01:17 PM
CanuckGal's Avatar
First Name: Deb
My mistakes NEVER look that GOOD! Very nice.
CanuckGal is offline
post #5 of 7 (permalink) Old 03-31-2009, 03:04 PM
First Name: Joe
Hi Deb,
If only I could make mistakes like that. Great job and good luck on the triangle box.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline
post #6 of 7 (permalink) Old 03-31-2009, 04:42 PM
xplorx4's Avatar
First Name: Jerry
That is one outstanding box, I like the finish and the burl top.
Lamentations 3:22-23
xplorx4 is offline
post #7 of 7 (permalink) Old 04-02-2009, 11:32 PM Thread Starter
boxman01's Avatar
First Name: john
thanks for all your kind words &the advice, thanks again
boxman01 is offline
Double sided tape sankarmohan Lobby 16 12-11-2008 11:31 PM
Walnut 4 Sided Bowl mit-ch Woodturning and Lathes 4 11-12-2007 02:53 PM
Cherry 8 Sided Bowl mit-ch Woodturning and Lathes 10 11-12-2007 01:26 AM
double sided tape? falcn63 General Routing 4 01-17-2006 02:48 PM
Brads VS. Double Sided Tape Pop_pop1 Jigs and Fixtures 8 08-18-2005 06:11 AM
