Musical jewerly box - Router Forums
post #1 of 8 (permalink) Old 05-15-2009, 04:06 PM Thread Starter
boxman01's Avatar
First Name: john
Default Musical jewerly box
this box was made with figured maple ,top, bottom, front & back with a wood called wamara for the sides, this wood comes from south america, the tapered feet is walnut & the joinerly is the E-Z Link system , there is a lift out tray inside made with spalted maple with sapele for the bottom, brass butt hinges, brass chain, & a oval mirror inside with the musical windup enclosed with maple burl , mahagony inlay strips were used on the lid, this box measures 12 1/2" X 6 1/8" X 6 3/4" high , the finish is natural danish oil, shellac on the inside & wipeon poly on the outside & 3-4 coats of wax to finish it off on the outside.
boxman01 is offline
post #2 of 8 (permalink) Old 05-15-2009, 04:14 PM
First Name: Sean
Beautiful box John. Those feet must of been a pain to make. I like how the joinery is carried through to the top. How did you make it so seamless? Did you saw it off afterwards?
fasttruck860 is offline
post #3 of 8 (permalink) Old 05-15-2009, 04:50 PM
Bob N's Avatar
First Name: Bob
John,
I do love boxes and love them even more after seeing yours. Excellent craftsmanship that really shows the beauty of the wood.
Nice job and thanks for taking the time to share it with us.
Bob N is offline
post #4 of 8 (permalink) Old 05-18-2009, 11:43 AM Thread Starter
boxman01's Avatar
First Name: john
Default musical jewerly box
the box was glued together & then i cut the lid apart using a 1/4" router bit, & using 1/4" square dowle in the routed side kept in place with masking tape , I cut around the box sides, to finish off I sanded each cut surface to make each surface smooth, as for the feet, I started with material 3/4" squaed & routed the inside rabbit & then shaped the outsides using my scrollsaw & sanding did the rest
boxman01 is offline
post #5 of 8 (permalink) Old 05-18-2009, 11:44 AM Thread Starter
boxman01's Avatar
First Name: john
thanks for the kind words
boxman01 is offline
post #6 of 8 (permalink) Old 05-18-2009, 03:06 PM
karateed's Avatar
First Name: Ed
Send a message via MSN to karateed
Hi John,
That's a real beauty....
Ed......:-)
karateed is offline
post #7 of 8 (permalink) Old 05-18-2009, 07:41 PM
Nice box great name.
vikingcraftsman is offline
post #8 of 8 (permalink) Old 05-18-2009, 08:30 PM
scrollwolf's Avatar
First Name: Jack
Beautiful box John. I like to combine the scroll saw with my router work too.
Jack
"If it ain't broke, don't fix it, give it to me!"
scrollwolf is offline
