Gears, Gears, Gears - Router Forums
 35Likes
  • 19 Post By kp91
  • 2 Post By Herb Stoops
  • 4 Post By jj777746
  • 1 Post By difalkner
  • 1 Post By rrrun
  • 8 Post By Gaffboat
post #1 of 7 (permalink) Old 05-25-2017, 09:05 PM Thread Starter
kp91's Avatar
First Name: Doug
Default Gears, Gears, Gears
This year for Vacation Bible School at Church the theme is 'Maker Fun Factory'. All of the decorating ideas revolve around gears, and other industrial stuff. The ladies who are decorating asked if I could cut them some gears to go on one of the walls. That was their mistake...
I ended up using a gear generating program to make a bunch of large gears with the same pitch and gear angle, and laid them out on a sheet of plywood to fit the wall that they gave me. I made the axles a little smaller, to allow for some slop and misalignment as I mounted them to the board. The real challenge came when I moved the plywood from horizontal to vertical, and had to deal with gravity. Every bit of misalignment caused for binding in the gears, and I had to make a few adjustments.
I had a simple hand-wheel arrangement, using a clip art plaque that I adjusted until it looked like a hand-wheel. This worked great until my 16 year old stuck her finger in the gears... which required a re-design and adding a layer of Acetate to keep little fingers at bay. Best to find this out at home, than with a 3 year old! I didn't want to buy anything else, so I stood off the leftover trim I had milled on the left over dowels. It kind of adds an interesting look. I added a cross bar to support the longer shaft for the hand-wheel, I don't like how clunky it looks. I should have cut some curves on it. Maybe I will add some caution stickers or a nameplate to break it up.
The ladies still may want to add more decoration to it, so everything is removable.
The acetate is thin, and as hard as I try, I can't get every ripple out. But I got it for $20, so I can't complain. In all, the only thing I had to buy was the sheet of 3/4 ply, the Acetate, and a 1 inch and 7/8 inch dowel. Everything else came out of my scrap bin, or from the 'free stuff' section of craigslist. I did break one 1/4 inch end mill, but that was me being stupid.
When it was all laid out, there were some blank corners, so I cut an extra gear and tacked it in place.
there was a lot of learning opportunities on this build, one being the differences in thickness for MDF from one batch to the next, another being to set the Z zero from the BOTTOM of the stock when cutting all the way through, to make sure that any deflection from clamping the thinner MDF stock is eliminated. Fortunately these were all fixable with a flush trim bit on the router table. Another tip to remember, make sure you cut on the side of the line you are supposed to when profiling. When your center hole is a LOT sloppy, that is usually the culprit.
Fun project, way too much dust, glad it's almost over. Hopefully this weekend I will be able to take it over to it's final spot, fasten it to the wall so it can't tip over, and glue some carpet pieces to the base so it doesn't tear up the floor.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #2 of 7 (permalink) Old 05-25-2017, 11:30 PM
That was a lot of work, Doug, it came out really good. I have always been fascinated with gears, and that should get a lot of attention from kids. I like the way you covered it with plastic sheet to keep the little fingers out of the gears.
Good Job.
kp91 and jj777746 like this.
Herb Stoops is online now
post #3 of 7 (permalink) Old 05-25-2017, 11:51 PM
jj777746's Avatar
Good Job.
Doug,I would not be surprised if some of the kids who see your work will want to become engineers when they are older.Brilliant job & thank you,James.jj
kp91, Nickp, Semipro and 1 others like this.
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is offline
post #4 of 7 (permalink) Old 05-26-2017, 06:26 AM
That's really cool, Doug! Funny that a 16-year old taught you, instead of a 3-year old. LOL
197761 is offline
post #5 of 7 (permalink) Old 05-26-2017, 06:36 AM
difalkner's Avatar
First Name: David
Excellent work, Doug! VBS is coming up soon at our church but I have so much work going right now I'm not volunteering anything like this - LOL!
David
kp91 likes this.
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is online now
post #6 of 7 (permalink) Old 05-26-2017, 08:50 AM
rrrun's Avatar
First Name: Henry
Perfect. Simply, perfect.
RainMan 2.0 likes this.
Henry
Santa Clarita, CA
www.MowryJournal.com
rrrun is offline
post #7 of 7 (permalink) Old 05-26-2017, 11:11 AM
Gaffboat's Avatar
First Name: Oliver
Oooooh! GEARS!! As you know, I love gears. Pardon me while I wipe the drool from my chin.
kp91, DaninVan, UlrichJ and 5 others like this.
Gaffboat is offline
Replacement gears for Craftsman 17542 fixed base router woodmeister34 New Member Introductions 5 08-05-2013 11:26 PM
Wooden Clock Gears Witchety Tools and Woodworking 7 03-28-2011 02:40 PM
cnc router wood gears beglylw CNC Routing 0 11-10-2010 09:57 AM
Wooden Gears or Cogs Thomo New Member Introductions 10 10-07-2010 08:36 PM
