Template guides question - Router Forums
post #1 of 5 (permalink) Old 01-28-2010, 03:58 PM Thread Starter
Default Template guides question
Hello, My name is Rick and live on the Western Slope of Colorado. I'm a carpenter and have finally pulled out my Porter Cable 4212 which I purchased years ago but have never used.
I'm running into some problems with the template guide part of things...
I have the needed template guides from P/C and a Bosch tempate adaper quide Part # RA1100. My problem seems to be that there is a fair bit of play with the bosch template quide in the router.
Can I make this template guide not move around or will I need some other type of template quide.
needlerockrick is offline
post #2 of 5 (permalink) Old 01-28-2010, 04:53 PM
Hi Rick
Sounds like you are using a Bosch router with PC dovetail jig, if that's the case pickup the item below and put the Bosch adapter back it the box, they suck big time.
Amazon.com: Milescraft 1201 Base Plate / Bushing Set for Routers: Home Improvement
http://www.amazon.com/Milescraft-121...ref=pd_cp_hi_1
post #3 of 5 (permalink) Old 01-28-2010, 05:49 PM
On vacation
First Name: Tom ( Template Tom)
Rick Not familiar with the Bosch and the template adapter guide part I usually purchase the dedicated guide for the router I have such as Makita or Hitachi, but I am sure there are many here who can assist you getting what you want to do with a router. Just a reminder; there is more that can be achieved when the router is held in the plunge mode, with the aid of the guides; check out the material below.
Tom
(Template Tom)
Tom76 is offline
post #4 of 5 (permalink) Old 01-29-2010, 04:05 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums Rick. Is the western slope of CO, like west of Denver and Littleton??????
Dave
the "Doctor"
Dr.Zook is offline
post #5 of 5 (permalink) Old 01-29-2010, 10:23 AM
allthunbs's Avatar
First Name: Ron
Hi Rick:
The template guide should not move at all. In addition to the solutions offered by the others (which I concur with) there is another option that is perhaps better -- Pull off the baseplate(s) and replace them with the OakPark baseplate and brass template guides. The brass guides are safer, less prone to come apart, and available in a broad range of sizes from both OakPark and LeeValley. Use only the 1 1/2" guides (with 1 3/4" counterbore) and you can get sizes almost to the magic 40mm size that Template Tom and his protègé, Harrysin, swear by Also the investment is not wasted when you change routers. Merely add a baseplate and continue using your existing guides.
Allthunbs
allthunbs is offline
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Looking for some advice on buying template guides Bonehead V.2 Guide Bushings and Templates 9 08-28-2009 10:08 AM
Half Blind Router Template Question stevek433 Guide Bushings and Templates 5 02-06-2009 09:23 AM
Hitachi M12V template guides? vwmowery General Routing 6 09-01-2006 12:51 AM
