Problem with Sabre 408 - Router Forums
post #1 of 3 (permalink) Old 02-16-2010, 09:47 AM Thread Starter
First Name: Jason
Default Problem with Sabre 408
Hello. I have been using a Gerber Sabre 408 router for 10 years and have recently come across a new problem. If I send a job that takes an extended time to complete or that requires multiple bit changes, at some point the axes go off and the machine routs/engraves right through my work. Usually it leads to bits breaking and/or an axis error. To get around this problem, I have been sending only small jobs or breaking bigger jobs into tiny pieces. This is time-consuming and just last week lost three hours of work by apparently sending too big of a "small" piece. The router flipped out and dragged right through several engraved plates. What is my problem? Please help.
JOdam is offline
post #2 of 3 (permalink) Old 02-16-2010, 06:48 PM
allthunbs's Avatar
First Name: Ron
Hi Jason:
I'm not in the CNC world but I spent a good part of my life in computers. Clean and test the logics on every part of your system. Especially, clean bus contacts and any plugs. Gently remove all push-in ICs and clean their contacts. If you have testing capability, you might also do a dump of chip contents to ensure their integrity.
Have you made any environmental changes recently? Office warmer/cooler? Take it step by step, carefully. You are in the third life from that equipment and you're dealing with pretty old technology. It's tired and needs attention.
Allthunbs
allthunbs is offline
post #3 of 3 (permalink) Old 02-17-2010, 03:07 AM
xplorx4's Avatar
First Name: Jerry
Greetings Jason and welcome to the router forum. Thank you for joining us.
Lamentations 3:22-23
xplorx4 is offline
PC plunge router depth gauge problem codgerbill Portable Routing 5 03-25-2010 09:50 AM
Another new guy, another problem! Billyt New Member Introductions 8 03-22-2009 01:14 AM
Problem with my Hitachi M12V Visteonguy Table-mounted Routing 23 08-19-2005 12:22 AM
Opening size in router table problem glassguy1456 Table-mounted Routing 2 02-28-2005 08:09 AM
Hitachi M12V Router Problem dcarriere Tools and Woodworking 3 12-28-2004 07:50 AM
