Hi, This is my first post. Fraser - Router Forums
post #1 of 4 (permalink) Old 11-12-2010, 10:39 AM Thread Starter
First Name: Fraser
Smile Hi, This is my first post. Fraser
Hi,
I'm new to the router but have been experimenting while building a kitchen island with raised panel doors and island ends. I bought a Ryobi router table and
freud 3 raised panel bits. I got along fine with the rail and stile bits but the throat of the table is too small for the 2.75 in. raised panel bit. Would I be better off buying a vertical bit or trying to adapt the table? Thanks! Fraser
Fraser is offline
post #2 of 4 (permalink) Old 11-12-2010, 11:14 AM
Ralph Barker's Avatar
First Name: Ralph
There are advocates on both sides of the horizontal vs. vertical panel-bit debate. Some say you'll get smoother cuts with the horizontal bit. A tall fence (12" or higher) is usually recommended for the vertical bits. With either, multiple passes are recommended.
Also, large diameter horizontal bits are usually the territory of the larger 3 hp routers, with variable speed (10,000 RPM is usually recommended for the biggie bits).
- Ralph
Ralph Barker is offline
post #3 of 4 (permalink) Old 11-12-2010, 11:31 AM
Hi Fraser
No big deal, just make a sub base plate for your router table,use some 3/4" thick MDF/plywood stock, cut a hole out for the bit to fit into (the norm would be 3 1/2" diam. for some of the chips to fall in ) clamp it to the top of your router table with a small slots for the fence to fit up to your setup..than you can use the bits you now have..make a stop block for your router on the under side of the table so it can't go to deep, many ways to make a stop block,the one I use is the stop block on the column, drill a hole in some stock, split it in 1/2 cut to the right size and tape it in place.. or use one of the threaded holes on the base and with a right angle bracket you have it set, or it can be some wire just to stop the router at the point you want it to stop at...
" vertical bits " you don't need a tall fence see below..it just take a pass or two with the jig in the picture
OR ▼ on a Horz. router table
http://www.routerforums.com/201461-post6.html
Originally Posted by Fraser View Post
Hi,
Name:	extra fence.jpg
post #4 of 4 (permalink) Old 11-14-2010, 04:59 AM
xplorx4's Avatar
First Name: Jerry
Greetings Fraser and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe.
Lamentations 3:22-23
xplorx4 is offline
First Post...first past the post...last post... post haste...repent at leisure... BigT New Member Introductions 20 09-01-2011 07:30 AM
*New* Report Post Mark Site Help and Suggestions 0 09-23-2008 01:19 PM
Forum Rules and Usage - Read this before you post! Mark Wood Scrolling 0 08-26-2006 05:57 AM
