Motor Voltage - Router Forums
post #1 of 4 (permalink) Old 11-12-2010, 12:43 PM Thread Starter
Default Motor Voltage
What's the preformace difference between the same cyclone dust collector with a 110 volt motor verses a 220 volt motor? My shop doesn't have 220.
Davis45 is offline
post #2 of 4 (permalink) Old 11-12-2010, 01:12 PM
Ralph Barker's Avatar
First Name: Ralph
Probably none, but the portion of your electric bill attributable to the 220v DC system will be about half. And, a 220v circuit would allow a higher HP system. Whether those considerations are worth the cost of having a 220v line installed is up to you.
- Ralph
Ralph Barker is offline
post #3 of 4 (permalink) Old 11-12-2010, 02:28 PM
Hi Davis45
Than it's not a big deal without a 220 volt setup you are SOL
post #4 of 4 (permalink) Old 11-12-2010, 02:53 PM
BigJimAK's Avatar
Davis,
The difference between the 120V motor and the 240V motor of the same HP is that the 120V motor will draw twice the current. This in turn requires larger wire (more expensive, less flexible) and larger amperage (but in the US physically smaller) breakers.
BigJimAK is offline
