problems with sears dovetail template 315.25710 - Router Forums
post #1 of 5 (permalink) Old 05-04-2012, 09:47 PM Thread Starter
First Name: ben
Default problems with sears dovetail template 315.25710
Several decades ago I made three workbench drawers using my new dovetail template. I recently blew the cob webs from the template, found my instructions and attempted to make some new dovetails for a piece of furniture. The manual said use a 7/16" pilot bushing with a depth of cut of 15/32". Unfortunately, with the dovetail bit I had, the smallest depth of cut is about 1/2" before the bit interferes with the ID of the pilot bushing. I (approximately) measured the angle of the (decades old) dovetails to be 11.8 degrees; they were made with Craftsman bit 25531 with no angle specified. My current bit was measured to be 12.8 degrees. Since 14 degrees is a common dovetail bit, perhaps 14 degrees is the correct angle; the bit is Bosch 85240. In the attached photo, the Craftsman bit has the longer shaft. You can see that the waist of the Craftsman bit is smaller than the Bosch bit. Any suggestions on a work around using currently available router bits would be appreciated.
bfblack is offline
post #2 of 5 (permalink) Old 05-05-2012, 03:26 AM
wbh1963's Avatar
Hello Ben,
Welcome to The Router Forums.
Dovetailing is something I haven't tried yet myself though I do have some interest in the technique and have done some research on it. My first attempts to make dovetail joints will most likely be of the type called 'sliding dovetail'.
I'm not sure whether the problem you are trying to find a work around for was an issue with 'depths' or 'angles'.
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #3 of 5 (permalink) Old 05-05-2012, 05:49 AM
Hi Ben and welcome to the forum.
Some of these old templates were designed to work only with a specific proprietary router bit.
If you cannot locate your original older bit, or find an alternate bit on the web, it may be time to invest in a newer dovetail template, I believe there are a number of inexpensive models on the market at the moment.
It may be a wise investment in the "piece of furniture"
Sydney, Australia
jw2170 is online now
post #4 of 5 (permalink) Old 05-05-2012, 06:01 AM
2 flute, carbide tipped.
Dovetail joints are mechanically strong as well as decorative.
Perfect for making strong joints on drawers, boxes and furniture carcasses
Bits fit most popular jigs (see Leigh Jig equivalency chart below.) Makes sliding dovetails, half blind dovetails, French dovetails, etc. Item #5396 is designed to be used for Sears dovetail jigs.
#5396 1/2" 15º 1/2" 1/4" $8.00
MLCS dovetail, candlestand router bits
post #5 of 5 (permalink) Old 05-07-2012, 07:46 PM
First Name: Frank
I purchased my new dovetail jig on line at Ebay. It has two jigs with it. It is realtively new. Just go to Ebay and put in Dovetail Jigs and you can find a great assortment to look at and decide what is needed. Some of the older jigs, I would not purchase. However, there is a lot of new stuff out there.
Tagwatts1 is offline
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Sears dovetail template instructions wv28 Guide Bushings and Templates 7 03-22-2015 04:01 PM
Craftsman Industrial Dovetail - Problems Using bloody thumbs Guide Bushings and Templates 6 08-14-2013 09:30 AM
Craftsman Dovetail Template Model No. 315.25710 david cooksey Jigs and Fixtures 10 06-25-2013 06:49 PM
For Sale: Sears/Craftsman 2579 router dovetail joint template kit. $25, Craigslist Anchorage BigJimAK Woodworking Classifieds 0 01-09-2010 07:40 PM
