Freud Carbide 2-1/8" Forstner RPM speed? - Router Forums
post #1 of 7 (permalink) Old 06-15-2012, 05:02 PM Thread Starter
Default Freud Carbide 2-1/8" Forstner RPM speed?
Newwwwwby here, I'm drilling into doubled 3/4" plywood (soft) and need to know the factory recommended rpm range. I'm using the Freud FC-016. Any help will be appreciated.
Bullybuster is offline
post #2 of 7 (permalink) Old 06-15-2012, 08:48 PM
Keep it in a drill. Forstners aren't meant to chuck in a router.
post #3 of 7 (permalink) Old 06-15-2012, 09:06 PM
First Name: Duane
I recommend 500 rpm or even less for a bit that size. as Charles said DON't run it in your router!
Dmeadows is offline
post #4 of 7 (permalink) Old 06-15-2012, 11:45 PM
Amazon.com: Magnate 1807 Hinge Boring Router Bits - 2" Cutting Diameter; 1/2" Shank Diameter: Home Improvement
http://www.amazon.com/s/ref=nb_sb_no...ng+Router+Bits
Product Description
This carbide tipped bit/cutter is specifically designed and manufactured for the high quality demanded by woodworking industrial applications.
The cutting edges of this router bit are made from high industrial grade micrograin carbide tips brazed onto a heat-treated high-carbon steel body thus leading to exceptional hardness and rigidity.
Good for creating recesses for hinges when using a hinge template guide and also good for cleaning out rough dado cuts.
For laminates, plastics, pressed boards and solid woods.
These bits create clean entry holes with smooth interiors.
post #5 of 7 (permalink) Old 06-16-2012, 12:17 PM
waynecochran's Avatar
First Name: Wayne
type in 'drill bit speed chart' in google and you will find many charts that will help. Wood magazine has one i like.
waynecochran is offline
post #6 of 7 (permalink) Old 06-17-2012, 07:40 AM
First Name: Clemo
Hi, 'n welcome. It is confusing, isn't it?
Freud publish in FAQ on their website, cutting speeds for very large router bits as fast as 3000rpm.
Many manufacturers however recommend 400rpm (hard wood) and 500rpm (soft wood) for Forstner bits. I use a chart from Australian Woodsmith, laminated by the drill press and it says 400 and 500rpm.
I'm thinking that router bits cut small chips and, for half their rotation, actually fly through fresh cooling air. (Ignoring the blind fence breakout solution.)
Forstener bits, on the other hand, produce shavings and do their work surrounded by wood and sawdust/shavings. Also, F-bits rely on their outer surface riding in the hole to keep them straight. Thats how they work.
F-bits get hot in a drill press at 500rpm, no way I'd spin one in a router.
But I'd be pleased to hear other opinions.
C ya.
Clemo is offline
post #7 of 7 (permalink) Old 06-17-2012, 10:56 PM
Welcome to the router forum.
Thank you for joining us.
As advised, I would not use a forstner bit in a router.....that is what a drill press is for......
Sydney, Australia
jw2170 is offline
Freud FT200E speed control module stjimm General Routing 8 06-28-2015 06:28 PM
How do I adjust the speed control on my Freud FT200E router? rimmer44 General Routing 5 04-22-2012 06:44 PM
Freud FT3000VCE 3-1/4 HP Variable Speed for $200 toddpolo14 General Routing 3 12-02-2010 09:46 PM
Please help - Dewalt Variable speed router - RPM just went beyond the max. paustin General Routing 14 10-30-2010 01:53 PM
Freud speed control module pedixon New Member Introductions 12 02-27-2008 07:26 AM
