Need a collet for Bosch 1611EVH - Router Forums
post #1 of 7 (permalink) Old 06-19-2012, 07:48 PM Thread Starter
Default Need a collet for Bosch 1611EVH
Hello! My name is Rich and I'm a total newbie at woodworking! I was given a Bosch plunge router 1611EVS TYP: 0601611734 to start me on my journey but it missing a collet however, I do have the nut. Do I need a 1/2 inch or 1/4 inch collet for this model?? I'm seeing a bunch on EBay at a decent price that will fit a 1617, 1618 and 1619 series routers. Will one of these work with mine? Any and all help would be greatly appreciated as I'm eager to start using this router!!!
Thanks so much!
Rich
rich_man is offline
post #2 of 7 (permalink) Old 06-19-2012, 07:53 PM
Welcome to the router forum.
Thank you for joining us, Rich.
Sydney, Australia
jw2170 is offline
post #3 of 7 (permalink) Old 06-19-2012, 08:59 PM
First Name: Wayne
Rich
You may want to try Bosch directly. Some models are not compatible with other models. I'm not familiar with Bosch, but if contact their customer service, they may be able to lead you in the right direction.
Best of Luck.
WayneMahler is offline
post #4 of 7 (permalink) Old 06-20-2012, 08:37 AM Thread Starter
Thanks!
rich_man is offline
post #5 of 7 (permalink) Old 06-20-2012, 09:13 AM
williamm's Avatar
http://www.routerforums.com/bosch/30553-1611evs.html
Found a manual for your machine on this site in the router section. Have a look-see and you may be able to answer your own question.
williamm is offline
post #6 of 7 (permalink) Old 06-21-2012, 01:23 PM Thread Starter
Awesome! Just what I needed! Thanks again
rich_man is offline
post #7 of 7 (permalink) Old 06-23-2012, 07:07 AM
Rich, any place that sells Bosch can order a new collet and nut for you. The 1611 uses a different, larger set than the 1617. Any time you need to order a Bosch part it helps to have the number off your router.
Broken Router Collet deanr Table-mounted Routing 12 10-26-2012 12:52 PM
Jacob's Power Collet Questions cdevlync General Routing 5 10-20-2010 11:07 PM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
