dewalt dw625 running slow - Router Forums
post #1 of 5 (permalink) Old 11-20-2012, 02:46 AM Thread Starter
First Name: Rob
Default dewalt dw625 running slow
Hi there, i have a dewalt dw625 router which only runs at half speed, I have changed the speed control unit, but to no avail , can anyone advise , regards Rob
Robbiedocs is offline
post #2 of 5 (permalink) Old 11-20-2012, 06:24 AM
Phil P's Avatar
First Name: Phil
Hello Rob and welcome!
Interesting, that. In my experience of using MOF177s and DW625s there are normally only three things which go wrong - brushes, bearings and (sometimes) speed controllers. What state are the brushes in? These can sometimes be an issue - I've even had cracked ones where tools have been dropped, but not that common. When powered off does the router turn freely by hand or does it stick? If it doesn't turn freely then suspect the bearings. What was it that caused you to suspect the speed controller? Sorry for all the questios, but I'm trying to come up with a solution
Regads
Phil
Phil P is offline
post #3 of 5 (permalink) Old 11-20-2012, 06:33 AM
Hi Rob. Welcome to the forum.
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 11-20-2012, 11:55 AM Thread Starter
First Name: Rob
Hi Phil, thanks for the reply, the reason I suspected the speed controller was that it runs at half speed or setting 3 but no higher, though it will slow down to setting 1, i bought a new speed control unit but it does the same , which leads me to believe it is something else , the bearing is fine but need to check the brushes , but in my experience you would see the brushes arcing through the top , any thoughts
hi james
post #5 of 5 (permalink) Old 11-20-2012, 01:55 PM
Phil P's Avatar
First Name: Phil
Hi James
Once they've bedded in they shouldn't really arc that much. I have to say that otherwise I'm a bit stumped, here. I've never had a DW625/MOF177 behave that way witjhout it being one of the three items I mentioned. I'll ask a couple of colleagues and see if they've ever had a probem like this
Regards
Phil
Phil P is offline
DeWalt DW625 Storage Case zig General Routing 7 11-06-2013 10:57 AM
For Sale: Dewalt DW625 3hp VS Plunge Router TanOak Woodworking Classifieds 1 06-16-2012 07:56 PM
Dewalt DW625 TanOak Table-mounted Routing 8 09-23-2010 08:44 PM
Problems with Dewalt DW625 pacodelrio Table-mounted Routing 9 10-15-2009 01:10 AM
Dewalt DW625 FineHomesCarpentry General Routing 4 10-30-2004 03:48 PM
