Boat repair - Router Forums
post #1 of 3 (permalink) Old 11-30-2012, 08:50 PM Thread Starter
First Name: Steve
Default Boat repair
I'm working on the wood parts of a 32-foot ferrocement sailboat that I've owned for some years. I have cut away rotted plywood and solid timber parts and am in the process of rebuilding. I have used scarf and half lap joints. I have an inexpensive 1/4" router and some hand-held power tools, and (at home) an old 8" table saw. The boat is on a mooring in the harbor. I have several 12-volt batteries, solar panels, and an inverter to provide 120 volts AC. So far the only tool that has failed to work is the 10 amp skilsaw. Steve
knotman is offline
post #2 of 3 (permalink) Old 11-30-2012, 09:25 PM
Welcome to the forum, Steve.
I would love to see some photos of the boat.
Sydney, Australia
jw2170 is offline
post #3 of 3 (permalink) Old 11-30-2012, 11:41 PM
Sounds like a lot of labour which would make this project a labour of love. Well built boats are both woodworking and art when done well. The skilsaw may be drawing too many amps which might drop the voltage too far down for the saw to work. The high amps/low voltage will cause the saw to heat up and premature failure. You may have to breakdown and go for a generator. Or go the old fashioned way and use hand saws. Good luck.
Replacing a fishing boat deck. Timco Lobby 5 07-19-2012 06:12 AM
Boat Building roxanne562001 Lobby 13 06-12-2012 04:39 PM
something different (boat building) mac_y44 DIY and Renovation 2 06-07-2012 06:13 PM
Rikon lathe repair shelhays New Member Introductions 2 07-26-2008 11:05 PM
