Mast R Lift problem - Router Forums
post #1 of 5 (permalink) Old 12-09-2012, 11:37 AM Thread Starter
First Name: Paul
Default Mast R Lift problem
Hi all, I'm Paul from Mi. I have enjoyed reading the forum, so finally registered.
I have been woodworking since I retired in (95) . I have the JessEm Mast R Lift,
#02102. Have always just used the fence or bits with bearings with no problems, now I want to use with bushings, but the router is not centered with the inserts. Does anyone know if there is an adjustment for this ? does not show anything in the manual.
Thanks for your help
Boxman3 is offline
post #2 of 5 (permalink) Old 12-09-2012, 12:48 PM
First Name: Jerry
Paul,
I don't have the answer you need, but if nobod,y on the forum comes up with an answer, I suggest that you get in touch with Mark Mueller the tech for Incra Tools. I bought my Mast R lift thrugh Incra Tools. So far I have not come across a problem with anything that Incra sells that Mark hasn't been able to help me with.
Good luck, and by the way, that lift is a great lift in my opinion.
Jerry
Jerry Bowen is offline
post #3 of 5 (permalink) Old 12-09-2012, 04:53 PM
Hi Paul. Welcome to the forum.
Sydney, Australia
jw2170 is offline
post #4 of 5 (permalink) Old 12-09-2012, 11:20 PM Thread Starter
First Name: Paul
Originally Posted by Jerry Bowen View Post
Paul,
Jerry
Thanks for the info Jerry. I'll try this if I don't get any ideas for a fix. I called JessEm and was promised a call back, but have not received it as yet. I may have to try them again.
Boxman3 is offline
post #5 of 5 (permalink) Old 12-09-2012, 11:22 PM Thread Starter
First Name: Paul
Hi James, Thanks for the welcome. Paul
Boxman3 is offline
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
Incra Mast R Lift II and Bosch MRC23EVS router.... CygnusX2112 Table-mounted Routing 6 03-06-2012 09:07 PM
Mast R Lift II on an Incra Router Table Petellie Table-mounted Routing 1 11-07-2011 07:31 PM
Help lift problem aurorasibe Table-mounted Routing 6 03-02-2011 07:44 PM
Rousseau 3002 Router Lift LS 46_trap Table-mounted Routing 2 02-18-2008 08:59 PM
