Bosch 1617EVSPK height adjustment issue - Router Forums
post #1 of 4 (permalink) Old 12-09-2012, 10:05 PM Thread Starter
First Name: Jerry
Default Bosch 1617EVSPK height adjustment issue
I'm in the middle of my second project with this router. This router was a huge upgrade over what I was using. Unfortunately, today the height adjustments quit working. Course adjustment and fine adjustment were both completely unpredicatable. Router was in a table. Following the above table adjustment rod rom the table to the router revealed a small cirlce that showed some friction marks. Eventually I figured out that something used to be there that was now missing. Searching through a small pile of wood chips revealed the missing clip. Once it was reinstalled, I was back in business.
Has anyone else experienced this clip coming off? I honestly don't know what I did that caused it to come off, but i assume it must have happened when pulling the router out of the table to change a bit.
jwilwerd is offline
post #2 of 4 (permalink) Old 12-09-2012, 10:26 PM
MT Stringer's Avatar
Yep. It happened to me recently. I bought a couple at the hardware store and was back in business. Now if only I could remember where I put the spare. :-(
MT Stringer is offline
post #3 of 4 (permalink) Old 12-09-2012, 11:01 PM
I had the same problem, once it pops off it will pop of easier the next time. Here is my fix and it worked very well and is still in use.
I got the little collar with a set screw in it and nylon washer at Ace Hardware.
Bill Huber is offline
post #4 of 4 (permalink) Old 12-10-2012, 05:09 PM
First Name: Barry
Yes, has happened to me, too. As Bill pointed out, once it happens it very well may happen again. I caused the problem the first time when I tried to adjust it beyond it's limit. It was when I first began using the lift in the table. Idiot that I am, I only looked at the bit height above the table and never looked to see if I was turning the adjustment knob too far. After doing the same thing a second time, I'm a slow learner, I now pay attention to were I am along the screw. Hasn't happened since.
Barry747 is offline
Bosch height adjustment rgardner41 Table-mounted Routing 6 10-21-2012 08:23 PM
Bosch 1617EVSPK or Bosch 1619EVS LBrandt Table-mounted Routing 25 01-19-2012 10:44 AM
Need a router w/ accurate and easy height adjustment in table use. WoodTroll Table-mounted Routing 26 04-10-2011 01:11 PM
Bosch 1617 ESV fine adjustment question horn man General Routing 5 01-21-2010 06:07 PM
Bosch 1617EVSPK Router table adjustment dtaylor15 Table-mounted Routing 10 07-27-2007 11:19 AM
