Elu 96e type 2 wiring help required - Router Forums
post #1 of 7 (permalink) Old 03-18-2013, 01:17 PM Thread Starter
First Name: Roy
Default Elu 96e type 2 wiring help required
Hi I'm a newbie to the forums so hi to everyone. Hope someone can help just received bearings for a ELU 96e router and replaced ok ,but have lost paper I jotted down the wiring for the electronic controller there are 2 browns 1 red and a blue. Hoping someone out there can help a silly old s**
Thanks in anticipation
Roy
smudgers2 is offline
post #2 of 7 (permalink) Old 03-18-2013, 04:45 PM
This sounds like one for Phil to answer. Welcome Roy.
post #3 of 7 (permalink) Old 03-18-2013, 06:05 PM
G'day Roy. Welcome to the forum.
Sydney, Australia
jw2170 is offline
post #4 of 7 (permalink) Old 03-18-2013, 06:21 PM
Phil P's Avatar
First Name: Phil
Hi Roy and welcome from the UK!
There are 5 connections which go to the speed controller. When viewed from the underside with the mini-spades to the left there are two browns which go to the leftmost pair of spades, two reds which go to the rightmost pair of spades NEAREST TO THE OPENING IN THE MIDDLE OF THE SPEED CONTROLLER and a single blue which goes to the rightmost outside edge spades (doesn't matter which one, they are connected). I'll try to get a picture of this, but as I'm having digital camera problems at the moment it could be a couple of days!
Regards
Phil
Phil P is offline
post #5 of 7 (permalink) Old 03-19-2013, 01:58 AM Thread Starter
First Name: Roy
Regards
Phil
Thanks a lot phil would be great help, only prob seem to only have one red!
Regards
Roy
post #6 of 7 (permalink) Old 03-19-2013, 05:57 AM
Phil P's Avatar
First Name: Phil
Hi Roy
There should be two, or at least there are on the one in front of me. One comes up from the rear, left side of the motor ("front" being the side with the "Elu" label), the other comes from the small circuit board at the front of the motor. This one is a model MOF96/02 typ 2. What's yours?
Regards
Phil
Phil P is offline
post #7 of 7 (permalink) Old 03-19-2013, 03:39 PM Thread Starter
First Name: Roy
Hi Roy
Regards
Phil
Hi Phil
Found second red must have pulled it down when I removed on/off switch to remove circlip. Router now works but variable speed not so good think probable old pole piece(bit missing). I ordered new one with bearings but lose on shaft will try some loctight. Once again thanks for your help
Regards
Roy
Elu MOF 177 Type 2 Raptorattacker General Routing 11 02-17-2016 05:08 PM
Elu Router 3338 Type 2 Manual bobp00 New Member Introductions 7 10-10-2014 08:21 PM
For Sale: Elu 96e plus table and dovetail jig TerryPorter Woodworking Classifieds 5 09-28-2012 01:21 AM
How identical are ELU 96e and DeWalt 615? janaf General Routing 1 01-30-2012 02:14 PM
Elu ST152E Type 3 jigsaw Pleb New Member Introductions 1 11-17-2010 03:15 PM
