edge banding with CMT 856.510.11 - Router Forums
post #1 of 8 (permalink) Old 10-14-2013, 11:58 PM Thread Starter
Country: New Zealand
First Name: Andros
Post edge banding with CMT 856.510.11
I have not used this bit yet but am not clear about how to register both bits to precisely the same finished surface level.The face layer of fines on MDF is pretty thin and so I want to avoid having to do any thing more than the absolute minimum of post-gluing clean off. Any suggestions suitable for an elderly amateur? Perplexed but hopeful, Andros
Polyphemus is offline
post #2 of 8 (permalink) Old 10-15-2013, 02:02 AM
Hi Andros, welcome to the forum.
I am not familiar with that bit. Could you post a picture.
Posting pictures:
Click on "Go Advanced" and then "Manage Attachments", then select your image file from your pictures on you hard drive.......
Sydney, Australia
jw2170 is offline
post #3 of 8 (permalink) Old 10-15-2013, 02:17 AM
Hi Andros.
Could you please check the number. I could not locate that number in the Carbatec range nor the CMT web site.
Sydney, Australia
jw2170 is offline
post #4 of 8 (permalink) Old 10-15-2013, 02:21 AM
CMT 855.510.11 2-Pcs Edge Banding Bit Set, 1-37/64-Inch, 1/2-Inch Shank - Amazon.com
It's a tricky bit on MDF ,the MDF likes to chip out so you must make a pass or two or three to get that nice clean edge.
Using a block of wood stuck to the edge with tape so have a backer board so to speak,to keep the edge down on the MDF.
The hardwood you will not have a problem with but use a wider stick and then rip to the size than you want to end up with, two sticks you could say at one time..
Just a note use the female bit 1st. and then put in the male part of the set and use female, to set the bit ..make a test part 1st to check the fit..
The same as the youtube below
http://www.youtube.com/watch?v=POvBhQo2ivQ
http://www.youtube.com/watch?v=x19iLZljTjo
http://www.mlcswoodworking.com/shops...banding_anchor
post #5 of 8 (permalink) Old 10-15-2013, 06:46 AM
Good find, BJ.
Sydney, Australia
jw2170 is offline
post #6 of 8 (permalink) Old 10-15-2013, 08:42 AM
If you haven't purchased that bit yet you might want to check the Burgess edge banding bit out. You don't lose as much wood using it. Burgess Edge Router Store | Router Bits, Shaper Bits, Shaper Cutter, Glue, Woodworking tools
post #7 of 8 (permalink) Old 10-18-2013, 04:58 AM
old55's Avatar
First Name: Ross
Welcome to the forum Andros.
old55 is online now
post #8 of 8 (permalink) Old 10-21-2013, 05:34 AM Thread Starter
First Name: Andros
re my question about setting edge banding bit:
1.Shamefaced aplogies to everybody, particularly to JW 2170,for a careless typo. The proper catalogue no. is 855-510-11 and not 856 etc.
2.Thanks bobj3for your full and helpful reply though the remark about MDF breakout confirms my suspicions of trouble to come.
Andros
edge banding spidennis Router Bits - Types and Usage 10 05-07-2013 09:24 AM
Edge Banding Bit Guarnera Router Bits - Types and Usage 7 03-08-2013 09:04 PM
glue for edge banding hintop New Member Introductions 9 01-14-2013 09:51 AM
Edge Banding bobj3 Project Plans and How To 0 09-23-2011 09:04 PM
edge banding blurry Router Bits - Types and Usage 2 01-22-2009 08:48 PM
