Air dry small quantity of wood indoors? - Router Forums
post #1 of 13 (permalink) Old 10-18-2013, 01:20 PM Thread Starter
First Name: Barry
Default Air dry small quantity of wood indoors?
Sorry in advance for the long posting. One of my neighborís trees fell over in a storm last spring and part of it landed in my yard. He never did anything about it, my wife was not happy, so yesterday I cut it up with a small chain saw. Since it was towards the top of the tree, the branches were not large but, I salvaged a log 5Ē diameter and 30Ē long thatís almost straight. Iíd like to try my hand at sawing it into lumber on my bandsaw. I have a ĹĒ woodslicer blade and figured Iíd build a sled to hold the log and give it a try. I know the Woodslicer blade is not designed for green wood but this is a small log and itís been down for over 6 months (not touching the ground). Iíd feed it slowly so the chips could clear. I figure that the very best I could get out of it are 3 boards 7/8Ē, and 2 boards ĹĒ, max 30 inches long. Once its cut Iím sure it will be less than that.
I know that air drying outside is the best way to dry wood. However, I donít have any kind of area to do that. All I have is a concrete slab in the back yard and in this area, northwest of Philadelphia, we can get wind driven snow in the winter and heavy, wind driven rain in the spring. My shop is in the basement. Now the question; can I dry it in my shop without totally screwing up the wood? Temperature is in the low 60ís all year round with normal home humidity which varies by season. We have a whole house humidifier for the winter. We also have a dehumidifier in the basement that rarely goes off. Of course, thereís not a lot of air flow other than when Iím running the shop vac. What do you think Ė sticker it, weight it and see what happens? Considering what I paid for it, if it became unusable, it wouldnít be a tragedy but Iíd like to do the best I can to make it work. Since this is totally new to me (all I know is what Iíve read on the internet) Iíd really be grateful for any and all suggestions.
I donít know if it makes any difference, but I think the wood is birch. Iím not sure since Iím not great at reading bark, Iím better with leaves, but the bark sort of looks like Birch. If itís a different species of wood would that make any difference? Finally, after I cut it I brought it into the garage and sealed the ends with 3 coats of Sealcoat shellac.
Barry747 is offline
post #2 of 13 (permalink) Old 10-18-2013, 03:12 PM
Semipro's Avatar
First Name: John_*
Barry
never try drying my own lumber but I have read about it I believe your biggest problem would be that it would dry to quickly causing checking
Thank You John
Semipro is online now
post #3 of 13 (permalink) Old 10-18-2013, 03:37 PM
JOAT's Avatar
First Name: Theo
Never gave it a shot either, but I would probably put it in the attic. Probably even better, the garage, if it's unheated. One never knows until one tries.
JOAT is online now
post #4 of 13 (permalink) Old 10-18-2013, 05:43 PM
I've dried lots, probably most of it was white birch. White birch is bad for twisting and bowing. It will probably be too warm and too dry inside. It also works better if there is a lot of weight on the pile, but it still needs good airflow past the faces and sides of the boards. You won't have much invested in this small amount of wood so give it a try. If the ends start to crack right away it's drying too fast. It is also better to keep it fairly dark too.
post #5 of 13 (permalink) Old 10-18-2013, 06:34 PM
First Name: Dennis
I have been playing with drying some cherry and apple for the last 3 years. I have it stickered in my unheated shed. Currently I am making a small box for my grand daughter from the oldest cherry pieces. These planed up perfectly. I don't think you will have a big problem drying inside. Drying outside exposes the wood to extremes of temperature throughout the year, particularly if you have a winter climate. A more regulated climate should be fine I think (but I've never done it). Make sure you use pine or other similar stickers so the wood won't pick up stains. Weight it very well. I use concrete blocks on top of a sheet of ply to distribute the weight. My attitude is that if it works it's great and if not well no big loss. Good luck.
denniswoody is offline
post #6 of 13 (permalink) Old 10-19-2013, 07:37 AM
Billy Boy's Avatar
Hi Barry. I air dry wood all the time in my live edge woodcraft business. I have found that the cooler the temperature the better. I use spacers between each piece and cement blocks for weight on the top of the pile to prevent warping. I think outside drying is better. You could tarp the wood pile. We do most of our drying in the winter and use fans to keep the air circulating around the wood. Inside would work if you could keep the temperature as low as possible. Good luck. Billy Boy Bill Major
Billy Boy is offline
post #7 of 13 (permalink) Old 10-19-2013, 10:51 AM
You might get some of the wax based liquid you paint on the ends of the boards to keep them from drying too fast and checking. Probably have to order it. Rockler has it, but I'm sure others do as well.
post #8 of 13 (permalink) Old 10-19-2013, 03:19 PM
I walked out past the woodshed this morning. It's wetter inside than outside! Basically a 14' x 16' 'carport' like structure with steel roof.
We're in the depths of a long-lasting fog bank, 4 days and no sign of burning off; everything is dripping wet, especially the underside of the metal roof! .
Ah the joys of living beside the ocean...
The dampness just cuts through whatever you're wearing.
DaninVan is offline
post #9 of 13 (permalink) Old 10-20-2013, 01:35 PM Thread Starter
First Name: Barry
Thanks for all of your suggestions. I'm going to try a middle ground, so to speak. I have an unheated garage. That's where the log is right now. As we go into the winter the temperature will be colder than the house and not subject to rain and snow. Not a lot of air flow but some since the garage isn't sealed all that well. On a windy day you can feel the breeze. I hope to to be able to cut up the log later this week. I'll let you know how it turns out in the spring. Thanks again.
Barry747 is offline
post #10 of 13 (permalink) Old 10-20-2013, 03:40 PM
I stored some in the attic of my shop once, which would be similar, and that turned out okay so it should work as well as anything else you could do. Good luck.
Setting Up a Small Wood Shop?? Advice Needed? WoodHaven Tools and Woodworking 63 08-31-2017 02:45 AM
Routing a groove on a small piece of wood Jackalope1966 Jigs and Fixtures 8 07-15-2012 08:28 AM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 04:01 PM
Sourcing wood for small boxes tomcoleman Starting Off 2 11-19-2008 10:32 PM
