Entry door making - Router Forums
post #1 of 7 (permalink) Old 10-22-2013, 05:49 PM Thread Starter
Country: Croatia
First Name: Tomislav
Cool Entry door making
Hi, my name is Tomislav and I am from Croatia. I plan to make some standard entry door for my house 200 cm high and 100 cm width from the wood 4,40 cm or 1-3/4"/ thick. The door should have 3 rails and 2 stiles /12cm width or 4-3/4"/ and raised panels. I was wondering how deep should my mortise be, do I have to make a through mortise and tenon joint?
tomislav000 is offline
post #2 of 7 (permalink) Old 10-22-2013, 06:05 PM
old55's Avatar
First Name: Ross
Welcome to the forum Tomislav.
Ross,
old55 is online now
post #3 of 7 (permalink) Old 10-22-2013, 07:16 PM
Semipro's Avatar
First Name: John_*
Hi Tomislav
Thank You John
Semipro is online now
post #4 of 7 (permalink) Old 10-22-2013, 07:51 PM
Welcome to the forum, Tomislav.
Sydney, Australia
jw2170 is offline
post #5 of 7 (permalink) Old 10-23-2013, 07:26 AM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Tomislav seeing no one else has said it then I will, go as deep as you can, old style doors were a 'through tenon' (using the word 'through' here means that the mortise went all the way through the door style and the tenon did as well) many older doors would have the tenon wedged as well, that is some cuts were put into the end of the tenon and a wedge has hammered in from the outside and that made the joint very strong, big heavy doors need to be as strong as they can be so go as deep as you can and use the best exterior glue you can buy. NGM
neville9999 is offline
post #6 of 7 (permalink) Old 10-23-2013, 04:21 PM Thread Starter
Country: Croatia
Thank you neville9999 for your advise, I will do the trough tenon and I'll wedge it.
post #7 of 7 (permalink) Old 10-23-2013, 07:21 PM
First Name: Larry
Hi Tomislav I recently built a 6 raised panel door for my shop. I don't know how to post pictures here, so I will start a new thread and maybe that will help. Welcome to the forum.
Knot working is offline
Entry level scroll saw RPM1954 Starting Off 28 06-24-2012 10:55 AM
[VOTE] 2011 Holiday Contest - Sponsored by Infinity Cutting Tools Mark Contests Archive 6 01-31-2012 09:26 PM
Entry door set ccmnova Router Bits - Types and Usage 0 04-04-2010 10:21 PM
freud entry door router bits Hat Router Bits - Types and Usage 1 07-22-2009 01:47 PM
?? Making entry door with a router tjschmi1 Table-mounted Routing 2 10-15-2005 10:57 AM
