Into, and what bit do i need for this shape - Router Forums
post #1 of 14 (permalink) Old 11-04-2013, 03:10 PM Thread Starter
First Name: Saf
Default Into, and what bit do i need for this shape
Hi
My name is Saf and I've recently got the bug to do wood work,
I bought my first router table and router, after research and bit a luck I got myself a
Charnwood Router Table Model No. W015
and
Triton 2000w Plunge Router Model no. TRB001
Can you please have a look at this picture, and tell me what router bit to use.
A. would i have to use 2 bits for this a square and then one with an angle, is that possible. the angle would be about 11-15%
B. i think i got this one now by using a dove tail router bit i can get this shape.
Its "A" that I'm struggling with.
Picture 2 shows you what I'm trying to achieve the glass is at angle
Thank you
gio.gee is offline
post #2 of 14 (permalink) Old 11-04-2013, 03:48 PM
old55's Avatar
First Name: Ross
Welcome to the forum Saf.
Ross,
old55 is offline
post #3 of 14 (permalink) Old 11-04-2013, 04:01 PM Thread Starter
First Name: Saf
Hi Ross
thank you
Nice to be here, there is a lot of information here.
I cant believe the title,
It was meant to Say "intro"
never mind
gio.gee is offline
post #4 of 14 (permalink) Old 11-04-2013, 04:38 PM
Welcome to the forum, Saf.
You could make that slot with a straight cutter and a chamfer cutter.
Personally, I feel that the slot, as shown, will not provide support for the front edgeof the glass.
Can you do an angled slot with a table saw?
Sydney, Australia
jw2170 is offline
post #5 of 14 (permalink) Old 11-04-2013, 04:48 PM Thread Starter
First Name: Saf
thanks for the reply
The angle shown is to wide,
If you had to do hold the glass in place and provide support to the glass,
what angle would you recommend and what router bit ?
So use a straight cutter and a chamfer cutter say 11% angle
gio.gee is offline
post #6 of 14 (permalink) Old 11-05-2013, 08:52 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Originally Posted by gio.gee View Post
Hi
and
Thank you
This is how I would do it, a bit slightly larger dia. than the glass thickness in a tilting base on my trim router. The wood is then ripped to width on the table saw. This would be an especially fast method for production runs, long boards slotted, ripped to width then cut to length. Several old trim routers have a tilting base as an accessory as shown on this one which I recently sold.
Harry
harrysin is offline
post #7 of 14 (permalink) Old 11-05-2013, 10:55 AM
I would either go with Harry's method or a table saw with a good dado set in it.You can't go too much angle on the groove or the torque from the weight of the glass might snap off the lip of wood holding it in place.
post #8 of 14 (permalink) Old 11-05-2013, 01:08 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Harry I was going to say what you have said, but you have said it first so thanks for that, N
neville9999 is offline
post #9 of 14 (permalink) Old 11-05-2013, 01:49 PM
Hi
I don't see what the big deal is, make one pass with the table saw then make one more pass with the blade set at 15 deg..
Hi
and
Thank you
post #10 of 14 (permalink) Old 11-05-2013, 03:39 PM
williamm's Avatar
I would use a dado set just a bit wider than the glass is thick and cut it at a10 degree angle.
williamm is offline
