Router insert help - Router Forums
post #1 of 12 (permalink) Old 11-09-2013, 06:16 PM Thread Starter
First Name: Dave
Default Router insert help
I have a beautiful cabinet left to me however the insert is beautiful BUT the hole for the bit is 1/16 off. should I take the insert to Rockler or somewhere and get a new insert ( if they have one) or just live with it. I guess just because its off I'll just measure each time. Please advise. The insert is 11x 9 x 1/4" thick. Thanks Dave Gale
dansdad is offline
post #2 of 12 (permalink) Old 11-09-2013, 06:44 PM
Welcome to the forum, Dave.
IMO, the difference of 1/16" should not make any difference, IF you are going to reference off the fence or use a bearing.
If you are going to use guide bushings than it will make a big difference.
Are you able to just re-drill the insert plate to the correct dimensions?
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 11-09-2013, 06:51 PM
Semipro's Avatar
First Name: John_*
Hi Dave welcome to forum.
Thank You John
Semipro is online now
post #4 of 12 (permalink) Old 11-09-2013, 07:32 PM Thread Starter
First Name: Dave
The hole being already drilled maybe I could take the top ( not the whole top) to woodcraft and get the center drilled and a shelf maybe set for a center. I don't know but I need a solid drill setup with a large holesaw???
dansdad is offline
post #5 of 12 (permalink) Old 11-09-2013, 09:06 PM
Question top or insert?
Hi Dave, we may be talking about different items.
I am talking about the insert plate in a router table, you seem to be talking about a "top" on a cabinet.
Are we on the same page?
Carba-TecŪ Router Table Insert Kit : CARBA-TEC
Sydney, Australia
jw2170 is offline
post #6 of 12 (permalink) Old 11-10-2013, 01:14 AM Thread Starter
First Name: Dave
Default router insert help
Can I het a plate that is adjustable for the bolt holes of the router so it is centered
dansdad is offline
post #7 of 12 (permalink) Old 11-10-2013, 01:17 AM Thread Starter
First Name: Dave
jw... the insert plate is not centered to the router bit it is 1/16 off
dansdad is offline
post #8 of 12 (permalink) Old 11-10-2013, 07:19 AM
First Name: Art
As long as the bit doesn't hit the side of the hole it will make no difference.
mgmine is offline
post #9 of 12 (permalink) Old 11-10-2013, 09:32 AM
david_de's Avatar
First Name: Dave
If the router was attached to the plate 1/16 off center it would make no difference I can see other than perhaps trying to use the plate to reference where the center of the bit is. It would be a problem if a bushing was installed in the plate as the bit would hit the bushing.
In most cases the router does not care how it is rotated in reference to the plate. Rotate the router a little and drill new holes centering it on the plate. Would that solve the problem? I have one old plate given to me that one more set of holes in addition to what is already there the center of the plate would fall out. It works but looks like hell.
david_de is offline
post #10 of 12 (permalink) Old 11-10-2013, 06:16 PM Thread Starter
First Name: Dave
I just came back from the woodworkers show and there were router plates there but they would not fit my top. Since my father in law made it the top is not a normal size that I could easily replace just by dropping in. I would need to get a custom insert for it and then drill. The bit doesn't hit anything just a little off. Since I'm just starting I would like to have things good, but I'll see if it works out. like you say it shouldn't matter
dansdad is offline
Making a Flat-Bottomed Candy Dish using a Router learnexperience Table-mounted Routing 2 12-09-2018 08:51 AM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
