Using 1/2 in bits with 1/4 in collet - Router Forums
post #1 of 8 (permalink) Old 11-29-2013, 03:36 PM Thread Starter
First Name: BILL
Default Using 1/2 in bits with 1/4 in collet
I bought a raised panel bit set without noticing the shank diameter. I bought in the USA but live 2000 miles away in Mexico. Any help would be greatly appriciated.
BILL
ROUTER BCMX is offline
post #2 of 8 (permalink) Old 11-29-2013, 05:26 PM
Welcome to the forum, Bill.
Not much can be done there.
It would be much safer to buy a 2 1/2hp router with 1/2" collet than try and use a 1/2" shank cutter in a 1/4" router.
I think you will also find that an older 1/4" shank router may not have the power for a raised panel cutter?
Sydney, Australia
jw2170 is online now
post #3 of 8 (permalink) Old 11-29-2013, 05:36 PM
Hi Bill and welcome to the forum. Any bit about 1 1/2" or over in diameter is likely to be 1/2" shank. Anything that large would apply too much torque on a 1/4" shank. I have seen a few vertical raised panel bits in 1/4" shank but I wouldn't recommend them. You would need to make a bunch of light cuts to get to the finished profile. If you want to make raised panel doors I would do what James suggested.
post #4 of 8 (permalink) Old 11-29-2013, 06:15 PM
Hi Bill
No big deal just take them back and pickup some 1/4" shank bits to do the job.
http://www.routerforums.com/table-mo...-4-router.html
BILL
post #5 of 8 (permalink) Old 11-29-2013, 06:38 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the forum. Bill
Thank You John
Semipro is online now
post #6 of 8 (permalink) Old 11-30-2013, 12:15 AM
old55's Avatar
First Name: Ross
Welcome to the forum Bill.
Ross,
old55 is offline
post #7 of 8 (permalink) Old 11-30-2013, 10:22 AM
You didn't mention which router you have. My Bosch (assembled in Mexico) 1617 has both quarter and half inch collets that are interchangable. Check on the web for a half inch collet for your brand of router. If you can't get a half inch for your router, I'd follow the advice of getting a router that has one. I agree that a quarter inch shank is probably too small for a large bit, and if your router is underpowered, you will have to make many light passes at very slow feed rate or risk. By getting a stronger new or used router with half inch collet you'll have a safer, more successful experience. By the way, welcome to the forum, many very nice and helpful people here with LOTS of experience.
post #8 of 8 (permalink) Old 11-30-2013, 07:57 PM
bcfunburst's Avatar
First Name: Reg
Default Make Raised Panels
I would also suggest that you just get a router with a 1/2 in. collet and be safe. A big router bit to do raised panels will need at least a 2 & 1/2 hp motor to do the job. You never have too many routers and more power the better. You will want a "Soft Start" motor as well, so don't go cheap.
You can also easily make raised panels on a table saw. You might need to make a few adjustments as you go, but the job IS safely done without "effort overload"
There are lots of instructional clips on "youtube" about making raised panels on your table saw.
Wishing you great results and good sawdust!! Let us know how you manage, please.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
Hi Joe Martines - mojo looking for a collet for my 1/2" router. I need 1/4 " mojo_jo New Member Introductions 6 12-30-2012 08:12 PM
Triton Dual Mode 1/4 router collet.. Snickare85 General Routing 13 12-29-2012 06:00 AM
freud 1700 - bits won't fit collet Boydpettitt General Routing 11 07-20-2009 07:08 AM
Installing bits in a tight collet Rowantree General Routing 8 07-09-2009 10:51 AM
First Bits rharveyva Router Bits - Types and Usage 6 03-20-2008 01:17 PM
