Problems changing bits - Router Forums
post #1 of 6 (permalink) Old 03-15-2014, 01:29 PM Thread Starter
First Name: john
Default Problems changing bits
This is my first post. I am an experienced woodworker but old age and arthritis have affected certain tasks. I use a Dewalt 611 for free-hand routing. It is especially nice to use for detail work like reducing the level of the background around a carving. My problem is that the Dewalt requires pressing in a detent while holding the body of the router and using a single wrench to change the bit. My left hand just doesn't grip well enough.
I have used the tail vise in my workbench to hold the router while pressing the detent. It works but is hard on the case. I have tried jamming in a screwdriver blade to lock the spindle and it works marginally.
While I like using the Dewalt because of the LEDs, my Bosch Colt is much easier to to handle during bit changes because it uses two wrenches.
I wonder if anyone with a similar problem has a better solution.
By the way, I use a 3HP Dewalt in my router table and really like the Router Raizer I attached. It is much cheaper than other above table router lifts.
johnjory is offline
post #2 of 6 (permalink) Old 03-15-2014, 06:38 PM
Welcome to the forum, John.
Sounds like a "MuscleChuck" should help you.
http://www.routerforums.com/portable...its-paces.html
Sydney, Australia
jw2170 is online now
post #3 of 6 (permalink) Old 03-15-2014, 07:05 PM
Semipro's Avatar
First Name: John_*
Hello John, glad you found us, it's great to have you as a member of the community, welcome to Router Forums.
Thank You John
Semipro is online now
post #4 of 6 (permalink) Old 03-15-2014, 11:04 PM
Honored Member
First Name: pat
Main reason I don't like these silly single wrench/armature locks.
That, and the fact you can't tighten the collet to spec.
The result of market issues, a penalty to the user, nutso.
No known solution & I have been through >50 routers.
Quillman is offline
post #5 of 6 (permalink) Old 03-15-2014, 11:52 PM
old55's Avatar
First Name: Ross
Welcome to the forum John.
Ross,
ĎMembers are requested to add a first name in their profile as we are a very friendly bunch here'.
old55 is offline
post #6 of 6 (permalink) Old 03-16-2014, 08:34 AM
Selwyn Senior's Avatar
First Name: Peter
My suggestion for your struggle in changing bits is to take the router to your nearest hardware store and work with someone there to find a pair of channel lock pliers that would circle the area and draw that annoying lock into place. Our Canadian Tire store carries a design similar to the shape used on an oil filter. Taking the routervwith you gives you a chance to experiment until you find what works.
Mobility stores dealing in aging also have a wealth of gadgets. They have something to help loosen jar tops which is like a pair of circular pliers.
Best of luck.
Selwyn Senior is offline
Whiteside dovetail bits not lasting long for me AronD Router Bits - Types and Usage 20 04-15-2013 02:17 AM
Changing Router Bits newbiejudy General Routing 6 05-23-2011 09:23 PM
Rate your personal experience with router bits ... riffin-rich Router Bits - Types and Usage 36 05-23-2011 08:43 AM
changing bits Michael Harding New Member Introductions 1 01-26-2011 11:50 PM
Dealing with depth when changing bits uOpt Starting Off 6 01-05-2009 02:14 PM
