Chicago Power Tools drill press model DP-558-2 - Router Forums
post #1 of 15 (permalink) Old 04-17-2014, 03:55 PM Thread Starter
First Name: Joseph
Default Chicago Power Tools drill press model DP-558-2
Hi,
Thank you for the welcome message. Really nice of you.
I am a retired sheetmetal worker. I am helping (trying to anyway) a friend to operate a Chicago Power Tools drill press, model DP-558-2. It is going in reverse.
Facing the press, on the right side of the body, just below the pulley section, is a handle with a rubber end-cap. Is the a forward/reverse lever? I can't budge it? Is it just rusted, or is there a something I have to push to be able to move the lever?
I'd like to get a manual.
Thank you again for greeting me to the Forum.
Joe Lapinski
jpl_8 is offline
post #2 of 15 (permalink) Old 04-17-2014, 04:54 PM
Semipro's Avatar
First Name: John_*
Hello Joe, Hope you like and enjoy the router forums make yourself at Home. Please participate by asking and answering questions, that is what makes this forum work!
Again welcome.
Thank You John
Semipro is online now
post #3 of 15 (permalink) Old 04-17-2014, 06:53 PM
Welcome to the forum, Joseph.
Sydney, Australia
jw2170 is offline
post #4 of 15 (permalink) Old 04-17-2014, 07:32 PM
BCK
First Name: BC
I know nothing of those..wish I could have helped...but maybe someone here does...without something obvious..button, lever etc, to unlock the lever for forward/rev,, just a thought..but is it possible that the lever can go in or out to unlock so no accidental movement...like if you push the whole lever inwards or pull outwards to activate the forward/rev...only thing I could think of other than jammed/stuck pin etc type thing..hope you know what I mean by move whole lever in or out to engage??? in or out may engage the lever on the shaft?, have seen similar on other type machines,, good luck and welcome aboard...
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #5 of 15 (permalink) Old 04-17-2014, 07:51 PM
H Joseph.
If you posted a photo of the drill press showing the lever, that may help.
Just a reminder that you do not need 10 posts to upload photos on your PC to the forums. Click the go advanced button and you will find a button that says manage attachments. Select this and you will be able to browse for, and upload your photos.
Sydney, Australia
jw2170 is offline
post #6 of 15 (permalink) Old 04-17-2014, 09:13 PM
old55's Avatar
First Name: Ross
Welcome to the forum Joe.
Ross,
old55 is offline
post #7 of 15 (permalink) Old 04-17-2014, 09:22 PM
First Name: Earl
Welcome aboard Joe. I'm not electrically inclined, but it almost sounds like the polarity may be reversed. It's not really likely that there would be a reverse on most drill presses. Any time i add an outlet i have to look up which terminal gets white/black, and it's also possible that somebody did some work on the motor and reversed a connection. If it's a 110/240 motor, make sure it's not wired for 220 with a standard 110v plug--a prior owner may not have switched to a proper plug.
As for the lever below the pulley cover--i'm attaching a few pictures of mine. The larger lever is most likely to draw the motor in/out for belt tensioning. You may find a smaller lever near it, and a similar one on the other side--on mine those are set screws for the motor mount shafts. Once they are loosened, the larger lever on the right (facing drill press) slides the motor in/out to loosen/tighten belt. On the left side, opposite the rods, is an adjustment for the return spring. I've never seen a manual for mine, but the return spring adjustment procedure is the same for many drill presses. Same with chuck/spindle removal--same for a lot of them. I struggled for months to find a manual for mine--no luck, but finally read enough other manuals to figure out that these are really fairly simple machines and many share similar characteristics. Good luck.
earl
greenacres2 is offline
post #8 of 15 (permalink) Old 04-17-2014, 10:00 PM
Hi Joseph and welcome to the forum. For the drill press to be manual reversible one of two conditions have to be satisfied. There either has to be a gearbox or a switch that is marked Forward/Reverse. If it is neither one of those then the motor is the wrong motor rotation or it has been wired wrong as some motors can be wired to go CW or CCW depending on the connections made in the connection box on the motor. The cover to the box will have wiring diagrams on it.
post #9 of 15 (permalink) Old 04-17-2014, 11:49 PM
JOAT's Avatar
First Name: Theo
A manual is probably available at Harbor Freight, but you'll have to dig a bit for it. Probasbly the lever is a belt tensioner. Did you even look at the belts?
Search results for: 'drill press'
JOAT is online now
post #10 of 15 (permalink) Old 04-18-2014, 12:02 AM
Default Is this similar?
From the look of the manual I saw for another model drill press, it sounds like the belt tension lever.
If the machine is running backward , it sounds like an electrical issue.
Sydney, Australia
jw2170 is offline
Chicago Machine Tools 12-Speed Drill Press kylehalchin Tools and Woodworking 11 01-20-2014 06:16 AM
thinning the drill press heard with a 120 volt VFD tool613 Tools and Woodworking 9 04-18-2013 08:15 AM
Delta 11-990 drill press older model question braunthrax Tools and Woodworking 11 05-19-2012 03:22 AM
harbour freight power tools? jeep_man Tools and Woodworking 27 05-20-2010 09:35 AM
Need info Chicago 5-speed drill press Birchwood Tools and Woodworking 14 10-22-2008 04:10 PM
