Jointech Templates and Manual - Router Forums
post #1 of 13 (permalink) Old 08-12-2012, 08:40 AM Thread Starter
CharleyL's Avatar
First Name: Charley
Default Jointech Templates and Manual
OK, here are the four Jointech template files plus the manual. These are for the Jointech IPM-1
The templates are about 260k in file size but the manual is 13.75 meg in size, so don't try to download all of them at once. The template files will need to be printed full size on a photo printer using heavy weight legal size paper and then carefully cut into strips that will fit into the fence extrusion of the IPM jig. Each strip is labeled on the end to show the size and style of joint being made.
Moderators - Please feel free to move these files to a more suitable place.
Charley
Central North Carolina
CharleyL is offline
post #2 of 13 (permalink) Old 04-16-2013, 02:39 AM
First Name: Robert
Default Jointech IPM-1
Charley,
Purchased the IPM-1 back in '93 and never got around to using it. I lost
the manual. Presently am semi retired and plan on either building a router table
or purchasing one to utilize the unique fence. Thanks for your post...
Bob
Charley
SnowOwl2046 is offline
post #3 of 13 (permalink) Old 11-01-2013, 08:38 PM
First Name: Brian
Thank you Charley, very helpful. Thanks for sharing!
Brian
K9lvr4ever is offline
post #4 of 13 (permalink) Old 11-01-2013, 11:08 PM
Smile welcome...
Brian
Welcome to the forum, Brian...
Sydney, Australia
jw2170 is offline
post #5 of 13 (permalink) Old 11-01-2013, 11:34 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the forum. Brian
Thank You John
Semipro is offline
post #6 of 13 (permalink) Old 01-29-2014, 03:38 PM
Charley, I have just purchased a JoinTECh IPM-1 on ebay. It works much like the Incra but with out the teeth!!! I have tried to down load the template files and print on an ink jet. I can not get the final copy to match the 10" length, they are +/- 3/32. How did you achieve the correct printing? I have a set of Incra templates, which fit the groves exactly. Has anyone used them on the Jointech? Any help would be appreciated.
dutton101 is offline
post #7 of 13 (permalink) Old 07-27-2014, 10:12 AM
First Name: Johnny
Hello everyone,
I know I am late to this conversation. I not only new to the Router Forum but new to woodworking in general (previously worked more with metal)
Charlie, (or any one who had successfully printed the templates) Thank you so much for the post. the information you have provided has furthered my use of my IPM1 greatly. However, I am having a problem printing the templates. You say to print them on photo paper in 8.5 X 14 size. I use CAD and downloaded the templates to it so I can measure distances and when I size the files to a 8.8 X 14 paper the measurements are about 1/16 or so different than if I print them - the difference is obviously the margins. Can you tell me if you are using an ink jet and what are your margins. or if you are using a photo printer without margins. I think that will help me and when I get the size right I can draw an accurate model of the templates and will post them here for others to use.
Rustbuster is offline
post #8 of 13 (permalink) Old 08-06-2014, 05:44 AM Thread Starter
CharleyL's Avatar
First Name: Charley
The files that I posted are in jpg photo format. I use an HP photo quality inkjet printer and photo paper to print them and have no problems with the strips. Just make certain that the printer software is set to print at 100%. The photo quality paper produces the best quality strips since it is a bit thicker and less likely to shrink.
Charley
CharleyL is offline
post #9 of 13 (permalink) Old 04-28-2015, 01:10 PM
Country: Thailand
First Name: Robert
Send a message via Skype™ to rhiekel
Hello : I am a new member here. I too have the complete Jointech
system. I used it to make some jewelry boxes that had hardwood
done in double double dovetails that were the marvel of my friends.
I no longer have the instruction manual, thanks so much for posting
it up . Is it possible a printing shop could print those strips out in
original plastic ?? My system has been in storage for the last 15
years while I have been living in Thailand. But am now headed back
and want to start wood working again...
rhiekel is offline
post #10 of 13 (permalink) Old 04-28-2015, 02:54 PM
Contributor of the Month
PhilBa's Avatar
First Name: phil
I have both an IPM and an Incra LS25 (templates work on both) and have been noodling with creating my own templates for custom joints. My plan is to laminate the strips so they are stiff enough to slide into the LS25 and IPM. I think you could print them on any paper if you laminate them. I would try to make it so the paper doesn't go to the edge so the plastic sticks together and forms a seal.
I have to admit, the LS25 is way nicer than the Join Tech product. Particularly with the locking mechanism.
PhilBa is online now
new member- Incra Templates dickhob Guide Bushings and Templates 3 04-08-2012 07:23 PM
Stanley Dovetail Jig 82913 Manual stanley dovetail Jigs and Fixtures 1 06-26-2011 03:30 AM
instruction manual moteeboy Lobby 1 10-13-2009 03:00 PM
Found: Wanted - Sign Letter Templates WES. WILLOUGHBY - Barrie, Woodworking Classifieds 2 10-21-2005 06:14 PM
