Skill 1817 Won't shut off - Router Forums
 5Likes
  • 3 Post By Mark Greisz
  • 1 Post By Cherryville Chuck
  • 1 Post By Stick486
post #1 of 4 (permalink) Old 12-05-2015, 02:49 PM Thread Starter
Mark Greisz's Avatar
Default Skill 1817 Won't shut off
If you have a problem with the on/off switch not wanting to go to the off position, pull the base, then remove the T8 (silver) screw. Pry out the switch cover from the middle of the motor body. You'll find all the wood dust that blocks the movement. To replace the cover it has to be bowed quite a bit to go back in place under the red part of the motor cover.
Name:	2015-12-05 11.43.42.jpg
swarfmaker, Stick486 and ksidwy like this.
Wantabe Woodworker
Mark Greisz is offline
post #2 of 4 (permalink) Old 12-05-2015, 03:12 PM
Welcome to the forum Mark. If a router won't start or stop quite often the culprit is dust in the switch. A lot of the newer routers have sealed switches that prevents this.
ksidwy likes this.
post #3 of 4 (permalink) Old 12-05-2015, 03:59 PM
Semipro's Avatar
First Name: John_*
Smile
Hello and welcome to the forum. Mark
Thank You John
Semipro is offline
post #4 of 4 (permalink) Old 12-05-2015, 06:34 PM
thanks and welcome Mark...
swarfmaker likes this.
Boomer bar clamps & skill saw plate. hawkeye10 Tools and Woodworking 8 10-30-2015 09:59 AM
SS. Rough Cuts with a skill saw AzOwl Tools and Woodworking 15 03-15-2015 06:31 PM
skill 1817 variable speed issue Travisphoto Table-mounted Routing 21 10-10-2014 04:01 AM
hello & skill lift plate? seanair General Routing 8 04-01-2012 07:47 PM
skill router accessories ua430jb New Member Introductions 2 11-29-2011 01:07 PM
