DeWalt 611pk Questions - Router Forums
 3Likes
post #1 of 17 (permalink) Old 09-13-2016, 11:13 AM Thread Starter
First Name: Tim
Default DeWalt 611pk Questions
Hi I just recently purchased a DeWalt 611 combo kit. I do have a few questions,I'm hoping it isn't an imposition,I've searched,but cannot find what I'm looking for.
The plunge base has a set of holes in it to attach an edge guide. There are two 81mm (I think) holes that go through the base that I think are used for an edge guide.However there are two more holes set above them that have recesses for a stepped set of rods to go into. Anyone know what the upper rod holes are used for?
The kit came with a somewhat poor bag to keep the kit in.I'm a little adverse to using it as I prefer not to have power tools banging around against each other. I was considering making a carrying case to store it all in. Oddly I can find no examples of such a thing. Does anyone ever build their own cases?
One of the things I purchased along side the kit was an edge guide the 6913. Apparently this was made to fit every DeWalt router.As a result it does not appear to be a precision fitted guide.In fact I don't like the looks of it and am hesitant to use it.What's the prevailing opinion on this guide?
Lastly does anyone know what thread size the wing bolts are on this model? I want to buy a few extra,as well as base mounting screws,but don't know what it needs.
Will likely have more questions,but I guess that will do for now..
Thanks For Looking
TWBryan is offline
post #2 of 17 (permalink) Old 09-13-2016, 01:53 PM
First Name: Scott
I have the PC 42690 Premium guide and it works great on my DW611 PK
Smokindog is offline
post #3 of 17 (permalink) Old 09-13-2016, 02:03 PM Thread Starter
First Name: Tim
Smokindog,I have the pc guide,but it is for a different router. I am thinking I'll see if I can buy the stud block from the other model and convert mine. Thought about just sending the 6913 guide back,but it probably cost as much to ship it as it cost to buy it.
TWBryan is offline
post #4 of 17 (permalink) Old 09-13-2016, 02:11 PM
schnewj's Avatar
Thanks For Looking
I suggest if you want to buy extra parts you go to the best sources.
Right to DeWalt support, or
DeWALT DWP611PK Parts List and Diagram - Type 1 : eReplacementParts.com
I would buy original parts. Sometimes they can be oddball lengths that are equipment specific. You may find, that, buying from the above two sources is cheaper then the hardware stores (even with shipping). You get the right part and no frustration.
schnewj is offline
post #5 of 17 (permalink) Old 09-13-2016, 07:01 PM Thread Starter
First Name: Tim
Thanks schnewj,can't afford to put more on the credit card for the moment,so I will try my luck at the hardware store...
TWBryan is offline
post #6 of 17 (permalink) Old 09-14-2016, 08:07 AM
schnewj's Avatar
Totally understandable. I just wanted to give you some viable options. You shouldn't have any problems getting the fasteners. I just wanted to point out that sometimes they are not standard lengths. This isn't a problem as you can always trim them back if they are too long.
I have actually gotten cheaper prices on some replacement part directly from the manufacturer's source, then some of the eCommerce sources on the net. Just something to keep in mind for the future.
schnewj is offline
post #7 of 17 (permalink) Old 09-14-2016, 10:13 AM
CharleyL's Avatar
First Name: Charley
The Dewalt wing bolts and springs that you are looking for aren't listed in the DW611 parts, but are in the 6913 guide parts list. In OEM Replacement parts for Tools, Appliances, Consumer Electronics and more | eReplacement Parts they are
not cheap, but they can be obtained. They will fit any of the DeWalt routers with the guide rod holes. The threaded holes in the top of the router base above the guide rod holes are where these go, and they lock the guide rods in position.
Screw,Wing
Part Number: 326573-01
Spring
Part Number: 868082-00
I like using my CRB7 router guide much more that the DW6913. With the extra guide rods
it will fit any router with guide rod holes. If you want a better and more precise edge guide that will work for many uses, look into the CRB7. I'm very pleased with mine.
You will still need the wing bolts and springs above to use it with your DW611.
Charley
Ed3443 likes this.
Central North Carolina
CharleyL is online now
post #8 of 17 (permalink) Old 09-14-2016, 11:16 AM Thread Starter
First Name: Tim
schnewj,yes,and I will reference your link next month and order about 4 of those,along with a pc stud block. For today I managed to find some bolts to attach a different base plate and some hex head to use on guide rods should I require them in the meantime.
CharleyL,thanks that will make finding them a little easier. I've read a bit about the crb7 router base plate/guide assembly.People seem to really like the versatility. I can't afford one right now. Next month I'm hoping to order a stud block part so I can use my current porter cable guide with the dewalt 611.
Eventually I'm thinking of buying a plunge base for my old 5615 Milwaukee router. I understand the routers are now made in china.Not sure where mine was made I bought it years ago.I figure adding the plunge base will be an economical way to totally replace the pc 8529.
No one makes carrying cases to protect their tools?
TWBryan is offline
post #9 of 17 (permalink) Old 09-14-2016, 11:23 AM
When we did the small router comparison testing the SBD Rep was kind enough to loan me a 611. I was uncomfortable with the offset handles; is this something that anyone else didn't like?
All of the routers performed well and it really comes down to personal preference.
Name:	SRC front view.JPG
post #10 of 17 (permalink) Old 09-14-2016, 11:52 AM
schnewj's Avatar
I do like my CRB7! Yes, it is a little pricey. I got mine from Hartville Tools a couple of years ago. It was around $80 complete. They had the newer model listed at the older model price. I got every thing but the edge guide.
Some will argue that they can make jigs to do everything that the CRB7 will do. True, but now you have to store a bunch of different jigs. The CRB7 only has a ~ 8x6x3 footprint in a drawer and takes little effort to set-up. This is a real plus for those of us who are space challenged.
I think that very few manufacturers supply blow mold plastic cases anymore. I rarely use them. I keep mine stored in drawers or on shelves. They take up less room. Again, space challenged. Most are now supplied with zippered soft cases with handles. Not much protection when transporting but somewhat easier to carry.
schnewj is offline
General router accessory questions, some DeWalt specific, some not Duane Bledsoe General Routing 27 02-07-2015 10:08 PM
Dewalt Jobsite saw questions. mikeoleary Starting Off 4 10-07-2012 12:17 PM
DeWalt 611pk deal bobj3 The Bargain Bin 2 06-07-2011 12:05 AM
DeWalt 611PK bobj3 Portable Routing 9 12-29-2010 03:18 AM
Dewalt 625 issues and questions Greg_R General Routing 9 12-11-2007 05:16 PM
