Festool OF1400 - Router Forums
post #1 of 6 (permalink) Old 09-27-2016, 10:44 AM Thread Starter
Jessica Randall's Avatar
First Name: Jessica
Send a message via Skype™ to Jessica Randall
Default Festool OF1400
Is the Festool OF1400 router compatible with the Milescraft base plate?
Jessica Randall is offline
post #2 of 6 (permalink) Old 09-27-2016, 03:01 PM
Welcome Jessica. Not many of us have that router so I don't know if anyone who does also has a Milescraft for it. The one picture I could find of the Festool's base appears that the base plate screws are equally spaced apart so I would think that that the Milescraft should fit it. If you were planning to buy online you could measure the spacing between the screws and distance from center and ask a supplier if matches.
post #3 of 6 (permalink) Old 09-27-2016, 04:08 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum.
email or call here Milescraft Customer Service.
[email protected] or 224-227-6930
Thank You John
Semipro is offline
post #4 of 6 (permalink) Old 09-27-2016, 06:28 PM
Honored Member
First Name: pat
If you run out of options, I make a 7" collar accepting plate for the 1400.
Quillman is offline
post #5 of 6 (permalink) Old 09-27-2016, 06:35 PM
Bob Adams's Avatar
First Name: Bob
Hi Jessica, I have the 1400, and my question would be what are you doing that you need to add a different base plate? It is a nice router but not very well suited for after market products.
Bob
Bob Adams is offline
post #6 of 6 (permalink) Old 09-29-2016, 05:29 PM
Guest
First Name: Regis
Jessica,
I have an EF1400 and it is accepted on the Milescraft offset base but only with two elongated holes. I've found that mounting to be secure enough and have used that base/router combination to be acceptable in table edge routing ( or any large piece edgeformed with a hand held router) with medium size router bits. For larger, say 1 1/2" thumbnail bits, I use an Elu 3338 which has a much larger body base opening than the EF 1400 but the Milescraft opening is too small for that sized bit. Bits at or larger than 1 1/2" are much safer used in a router table with a substantially more powerful router. If you have to edge a very large piece with a large diameter bit you'll need a bigger router and an offset base you make yourself or purchase from a supplier like Quillman (Pat Warner).
Hope this helps,
Regis
Last edited by 48394; 09-29-2016 at 06:01 PM. Reason: EF1400 body base opening restriction
48394 is offline
Festool competition londonjoiner Lobby 7 03-08-2016 02:28 AM
Anyone use a Festool track saw ? RainMan 2.0 Tools and Woodworking 39 07-03-2015 04:07 AM
Festool OF1400 EQ Router, Photos and Accessories Notes timbertailor Festool 0 05-08-2015 12:01 PM
festool of1400 liano31 New Member Introductions 2 11-29-2010 01:56 AM
Festool OF1400 Pieters New Member Introductions 3 10-22-2006 06:25 PM
