Plan "B" for repairs to Trend T3 router - Router Forums
 1Likes
  • 1 Post By pinehunter
post #1 of 2 (permalink) Old 10-19-2016, 02:02 AM Thread Starter
First Name: dave
Send a message via AIM to pinehunter
Default Plan "B" for repairs to Trend T3 router
If the attempted speed controller repair goes wrong this is plan B. A triac based unit that is fitted in an enclosure and located in series with the power cord. It will be free of vibration and should do job. A bypass switch may also be included to ensure maximum speed can be obtained.
Cherryville Chuck likes this.
pinehunter is offline
post #2 of 2 (permalink) Old 10-19-2016, 03:19 AM
direct wire the motor to make it a single speed and use an external speed controller...
Router Speed Control
Freud FT2000 into a Trend PRT router table - DRILLING! sammy.se Table-mounted Routing 4 08-14-2014 04:26 AM
Router Backup yuva New Member Introductions 6 01-21-2014 08:33 PM
Help on mounting triton guides (TGA001) on a router table dex2008 Table-mounted Routing 9 08-23-2012 06:38 PM
Plan: adj. router mount Johnmolding General Routing 4 10-04-2010 05:54 PM
Router top plan in mind mntbighker Table-mounted Routing 1 01-01-2008 06:25 AM
