oiling fine adjuster on Bosch MRC 23(GOF 1600ce) - Router Forums
 4Likes
post #1 of 15 (permalink) Old 03-15-2017, 08:04 PM Thread Starter
First Name: Peter
Default oiling fine adjuster on Bosch MRC 23(GOF 1600ce)
Hi
may I ask if anyone has oiled the fine adjuster on the above plunge base router?
The local Bosch people here in Australia will not tell how this is done.
Peteroo1 is offline
post #2 of 15 (permalink) Old 03-15-2017, 08:26 PM
Oil or grease and wood dust are a bad combination Pete. I would something that dries without any stickiness. Same goes if you lube the plunge tubes.
post #3 of 15 (permalink) Old 03-15-2017, 08:33 PM
Nickp's Avatar
First Name: Nick
Maybe you can describe what's going on...? why Bosch won't help...?
In any event, this diagram indicates a top screw and 3/4 screws hold it all together in the plunge base and different arrangement for the fixed...pick your poison...you can also see some c-clips in the mix...
Bosch GOF 1600 CE / 3601F24070 Spare Parts | Miles Tool & Machinery Centre
Are you having problems with it...? Why do you think it needs "oiling" ?
Others will jump in for sure...
...and welcome to the forum...
Nick
Nickp is offline
post #4 of 15 (permalink) Old 03-15-2017, 09:11 PM
old55's Avatar
First Name: Ross
Welcome to the forum Peter.
Ross,
old55 is offline
post #5 of 15 (permalink) Old 03-15-2017, 09:33 PM
Semipro's Avatar
First Name: John_*
Hello and welcome to the router forum.
Dust is us Usually the problem tooth brush and air and clean the adjustment screws maybe a little dry lubricant and wipe that down you will not need much
Shop guy likes this.
Thank You John
Semipro is offline
post #6 of 15 (permalink) Old 03-15-2017, 09:49 PM
First Name: Richard
What John said.
Shop guy is offline
post #7 of 15 (permalink) Old 03-15-2017, 09:51 PM
Originally Posted by Peteroo1 View Post
Hi
listen to Cherryville...
use a dry lubricant.......
jj777746 likes this.
post #8 of 15 (permalink) Old 03-15-2017, 10:11 PM
jj777746's Avatar
Lightbulb Oil & sawdust
Peteroo,Hi Peter,if youtake notice of the advice given by the more experienced Router Forum members & Moderators,you cant go wrong. Compressed air,brush & dry lube the way to go. BTW thought I saw a post from you previously yet it says"first post",is there another Peteroo?.Jamesjj777746
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #9 of 15 (permalink) Old 03-16-2017, 11:21 AM
chessnut2's Avatar
Welcome, Peter. I hope someone suggests a specific dry lubricant, because I need to know this, too.
chessnut2 is offline
post #10 of 15 (permalink) Old 03-16-2017, 11:49 AM
Nickp's Avatar
First Name: Nick
Product called "TriFlow" with PTFE...2 oz bottle should last a while. Doesn't need much to lubricate...as has been said to me "when you think it isn't enough, it's already too much"
Roy Drake and jj777746 like this.
Nick
Nickp is offline
bosch gof 1600ce under base dust hood Peteroo Portable Routing 6 01-02-2017 11:06 PM
Bosch GOF 1600CE Peteroo Portable Routing 5 01-12-2016 06:54 AM
Fine adjustment of Bosch GOF 100 ACE militarymad Bosch 7 05-25-2015 02:43 PM
Bosch 1617 ESV fine adjustment question horn man General Routing 5 01-21-2010 06:07 PM
