Fine height tuner problem from new. - Router Forums
post #1 of 1 (permalink) Old 03-16-2017, 06:51 PM Thread Starter
Default Fine height tuner problem from new.
Hi again all
the problem with my Bosch GOF 1600CE has been from new. The fine adjuster is enclosed and above the lock turret. I bought a fixed base from Amazon and found that using an oil which actually TREATED THE METAL really fixed the stiffness in that new base which is now silky smooth. I used Bitron penetrating oil for this process in the exposed areas where friction was occurring. However the enclosed fine adjuster in the plunge base is another matter. Has anyone else had this problem out of the box?
Peteroo
Peteroo1 is offline
Building a New Router Table-What's the Ideal Working Height? gerrym526 Table-mounted Routing 12 07-19-2014 08:49 PM
Newbie question about above table height adjustment patdavid Table-mounted Routing 6 02-13-2013 04:46 AM
Problem with height adjuster Glenmore General Routing 8 11-24-2004 07:55 AM
