Inlay Rookie - Router Forums
 13Likes
  • 1 Post By Herb Stoops
  • 6 Post By Semipro
  • 2 Post By DesertRatTom
  • 1 Post By Stick486
  • 3 Post By TwoSkies57
post #1 of 8 (permalink) Old 04-12-2017, 03:14 PM Thread Starter
KhalTom's Avatar
Default Inlay Rookie
I want to start doing some inlays...I do not foresee myself getting too ambitious , right now I'd just like to do some strait channels and inlay strips of Wenger across some joined pieces to kind of look like metal bracing on a door...If that doesn't make sense it looks really good in my head.
Anyway to do inlays , is their a router that makes more sense than others? I've been a refinisher for years, I'm just now venturing into building my own projects. It seems to me, and I'm just spitballing here, a monster router like the Triton 3.5 HP would be more difficult to manage for work like this. That's what I have on my table and I'd rather leave it there.
I'd really appreciate some of your guys recommendations. I was eyeballing a D handle or the Bosch with wood knobs, but that's just me guessing. Don't even know if the D handle would make sense. Please feel free to talk to me like I'm a child, I'm not too proud to admit my knowledge is almost non existent in this area. Everything I've learned so far has been from YouTube.
Sent from my Pixel XL using Tapatalk
KhalTom is offline
post #2 of 8 (permalink) Old 04-12-2017, 04:55 PM
JOAT's Avatar
First Name: Theo
How childish of you, thinking utube will teach you anything.
Well, yes it can actually, but first you have to wade thru all of the BS, which often means hip waders.
I don't inlay. Because I don't have anything I want to inlay mostly. I know the principals and all, but any experience would be many years past.
So, first thing I would do is - go to my local library, and see what they have. Next a good book store - but I would NOT buy anything by just the title, I'd want to know what the book actually contained first. I already have a good woodworking library, and I know there are books I have that do cover inlaying. I do like utube, but 99% for entertainment value, seldom to actually learn something. But that said, I have learned a thing or two from it, mostly how to not reinvent the wheel. And use google. If your first search phrase doesn't find what you want, change your search phrase, repeat as needed - that's usually the way I do it. And I save what I find useful, to peruse it again later.
Oh yes, practice on cheap wood, left over wood, junk furniture, whatever, before you try the 'spensve stuff.
I just googled 'how to inlay' and came up with - https://www.google.com/#q=how+to+inlay&spf=1
JOAT is online now
post #3 of 8 (permalink) Old 04-12-2017, 05:29 PM
Tom, I don't do much inlaying ,but I use these PC inlay bushings and bits .
https://duckduckgo.com/?q=Router+inl...nt&ia=products
Then you only need a template to follow.
I like the use a trim router with a hole in the base plate to accept the (PC) Porter Cable, router bushings, which are pretty much a standard bushing.
I also use the Dremel as a router with the router base for small inlays.
MEBCWD likes this.
Herb Stoops is online now
post #4 of 8 (permalink) Old 04-12-2017, 06:16 PM
Semipro's Avatar
First Name: John_*
Default Rose
Not that difficult to do, Depends on the inlay start out simple like circles or diamonds
Here a place that sells and show you how and sells some products for use in inlays
Tarter Woodworking Inlays - Multi-Layer Inlay Templates
Check how to on their web site
Here one I did on a jewelry box
I bought a rose flower kit but you can design your own
There are a few different places that sell kits
Inlays made easy is another one
I use a dewalt 611, you usually Are only cutting a 1/8" to 1/4" deep need more control then power
Semipro is online now
post #5 of 8 (permalink) Old 04-12-2017, 06:19 PM
A fairly recent episode of Tommy Mack featured a woodworker who was an artist at inlay. A lot of the inlay was assembled first, then the slight recess created for the overall shape of the inlay. Couldn't find that video, but use this search for YouTube for a huge number of helpful videos.
I recently bought, but haven't used yet, a Veritas Router Plane with an inlay cutter accessory. Pictures below. You use the cutter to cut the outline to a precise depth (Thickness of the inlay), then the L shaped blade to scrape it out with a perfectly flat bottom. You can do this with a router, of course, but hand tools will give you even better control.
Here's a Lie Nielson video:
MEBCWD and TenGees like this.
post #6 of 8 (permalink) Old 04-13-2017, 05:47 AM
http://www.routerforums.com/show-n-t...azy-susan.html
Herb Stoops likes this.
post #7 of 8 (permalink) Old 04-13-2017, 03:18 PM
Keep it coming,there is some good stuff here.
post #8 of 8 (permalink) Old 04-14-2017, 08:04 AM
TwoSkies57's Avatar
Welcome to the community Tom....
Straight line inlays like I believe your describing are arguably the easiest to do and can be accomplished a number of different ways. You could get away with a good straight edge (typically a metal ruler) as your guide. A thin sharp edged cutting tool. Could be anything from a box cutter to a scalpel. I really like using scalpels! And a nice sharp chisel. This process is labor intensive, but what you learn carries forward to other methods and techniques.
Use of a router plane is another option. And a very good one. I have the complete setup that Tom mentions above from Lee Valley (veritas). It is nothing less than a high quality tool! Capable of clean groves and smooth bottoms. Downside is cost and it is limited to pretty much straight line groves. A task that can be achieved by much less expensive means. The inlay cutter head is a VERY COOL option for their router plane. Takes a little getting use to but boy, does it do a nice job. Allowing for radius grooves this accessory is what sets this group of tools apart. Taking the design potentials to another level. More narrow channels/groves can be cleaned out using their inlay chisels, wider groves can be easily cleaned using good sharp shop chisels.
>>>>Veritas inlay tools<<<< Lee Valley Tools - Item Search Inlay Cutter Head for Veritas® Router Plane - Lee Valley Tools
I also have several of the Lie-Nielsen inlay tools. All high quality tools!!! None of em cheap though. https://www.lie-nielsen.com/search?q=inlay
In all fairness, very few of the high dollar tools accomplish anything that can't be done with much less expensive means. Convenience and ease of setup, accuracy and repeatably is what tends to set them apart from other tools. That and the fact that they are just simply a pleasure to have and to use. Personally I most of the Veritas stuff and find it all excellent.
If a router is what you feel comfortable with, I'd suggest the Bosch Colt with the plunge base option. Plenty of power for inlay work, limited to 1/4" shank bits. Small enough to be easily manipulated yet big enough to not feel flimsy in your hands. Easily controlled/guided over the work piece. Visibility of where the bit meets the wood is fair to midlin as is the case with most small routers. While doing inlays, chip extraction isn't too big of a deal since most passes are shallow by nature. With a full line of accessories available including guides, more than enough power and adjustable this one is my favorite for inlay work. If you want a router that is a little more versatile (general shop use as well), the Dewalt DWP611PK compact router kit is well worth a long look.
Always take the time to size your banding/inlay to the tool you are using. Its not unusual to find straight inlays are undersized width wise. Cutting a 1/4" wide groove only to find that the inlay is 7/32" or less wide can be very annoying!!
Regardless of the method/technique used, PRECISE layout is a must. If you are looking for professional results you got to get your layouts spot on. Spend an afternoon or weekend practicing what it is your trying to accomplish. First couple of tries, use a soft wood, pine or better yet popular. Once you got a feel for what is going on and what to expect, try it on a piece of the wood you are going to be working with. The woods density/hardness/grain patterns all introduce little deviations into process that if unexpected will just create alot of unnecessary frustration. Some folks find that depending on the wood, scoring the cut prior to making a pass with a router lends itself to a much sharper/cleaner edge. The cleaner the cut, the better the inlay will look. Sharp tools are a must as are precise layouts. IMHO straight line inlay is not all that difficult with a little practice. The devil is in the details though. There are ALOT of good quality video's out there on "how-to". Including youtube! Spend some time just watching the variations on a theme. I can almost guarantee you that when you get that first piece just the way you want it, you'll be hooked on inlays and what they can add to a project. And it only gets better from there...simple string inlay work, well done can take a project from ordinary to extraordinary with just a little extra work. I realize this is all kinda vague and all over the place, but there is an awful lot of ground to be covered in a short post. Once you get started, post your questions and concerns. There are alot of top shelf wood workers in here that will be more than willing to help you along..
Bill
Skipper the Penguin
TwoSkies57 is offline
Wood Inlay Templates-More Possibilities w/ More Layers TarterWoodworking Jigs and Fixtures 10 06-08-2015 06:55 AM
Inlay Material Thickness KomputerMan General Routing 6 10-21-2014 01:39 PM
Making an Inlay and Inset Drawer Pull learnexperience General Routing 0 10-31-2011 06:48 AM
Inlay and wood movement verteramofurniture Guide Bushings and Templates 3 02-16-2009 02:45 PM
Inlay Chart/Update bobj3 Guide Bushings and Templates 3 12-19-2008 08:59 AM
