Alternative Wrench - Router Forums
 1Likes
post #1 of 15 (permalink) Old 06-05-2017, 05:29 PM Thread Starter
Default Alternative Wrench
I just purchased my first router - Chicago Electric plung router. Stupid me, I thew away the wrench for the collete (?) nut. Any suggestions on what I can use in place of this wrench? I haven't even used the router yet!
Cory C Williams is offline
post #2 of 15 (permalink) Old 06-05-2017, 07:34 PM
kp91's Avatar
First Name: Doug
Call harbor freight. They may surprise you with their customer service.
I use a regular combination wrench with my porter cable, you might find the flats on your collet match a standard wrench
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 15 (permalink) Old 06-05-2017, 07:54 PM
MT Stringer's Avatar
Check your users manual. Might be something like a 23mm wrench. Go buy one and get after it.
Also, check out this wrench. I bought it to use on my Bosch 1617.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I think It will also fit the Harbor Freight model. I had a router table with dedicated router mounted in it and the collet was the same size as the Bosch.
MT Stringer is offline
post #4 of 15 (permalink) Old 06-05-2017, 10:04 PM
JOAT's Avatar
First Name: Theo
I have a wrench that fits, but have been known to use a crescent wrench on the rare occasion. Tight fit, and slow going, but works. I only did that when I couldn't find my router wrench, so now I have it hanging on a nail, and make sure I hang it up again when finished with it.
JOAT is offline
post #5 of 15 (permalink) Old 06-05-2017, 11:16 PM
put it back after you're done with it. There is the secret to a happy life! I have a long nut on my router table for the wrenches, the threads help keep a grip on the wrench.
DesertRatTom is online now
post #6 of 15 (permalink) Old 06-06-2017, 12:12 AM
old55's Avatar
First Name: Ross
Welcome to the forum Cory.
Ross,
old55 is offline
post #7 of 15 (permalink) Old 06-06-2017, 12:46 AM
Welcome Cory. As stated, any wrench the right size works. It's either metric or Imperial but I would hedge a bet on it being metric.
post #8 of 15 (permalink) Old 06-06-2017, 10:07 AM
Garyk's Avatar
First Name: Gary
You local Harbor Freight can give you a phone # and/or a web address for their Customer Service in CA. I needed it for a spring in a paint sprayer but found one locally at ACE hardware.
Garyk is offline
post #9 of 15 (permalink) Old 06-06-2017, 10:33 AM
roxanne562001's Avatar
First Name: Roxanne
I do allot of metal work as well as wood work. I made a few thin offset wrenches for my router table. I cut them out of an old lawn mower blade with an acetylene torch and a hand grinder. I then hardened and tempered them by quench cooling in oil and heat treating. I would think harbor Freight customer service could help you out but if they can't you can always make one. If you measure the size of the nut find a wrench that is the right size. If the wrench is too thick just grind it to make it thin enough to fit take a little at a time and keep the wrench cool by quenching make sure it it doesn't start changing colors like to blue or brown that means the temper is coming out. Hope that helps and welcome to the forum.
roxanne562001 is online now
post #10 of 15 (permalink) Old 06-06-2017, 11:05 AM
First Name: frank
Default router srenches
I have just found the wrench that fit and ground it to the thin size I needed to fit. Thirty minutes at most. You can also use the older wrenches we used to use years ago to adjust valves on the old "L"Head motors. This was before overhead valves. They are very thin and work well. This kinda dates me, but they will work. Napa stores still carry some of these, I believe.
Tagwatts is offline
Shaft wrench for Bosch 1617EVS nn4jw Table-mounted Routing 9 02-17-2014 10:06 AM
Above table shaft wrench Bosch 1617EVS nn4jw Table-mounted Routing 0 07-31-2013 11:58 AM
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 10:25 AM
Help with Delta arbor wrench horn man Tools and Woodworking 4 03-04-2010 03:31 PM
Found: Looking for an above the table depth wrench jmoo Woodworking Classifieds 7 01-04-2010 01:40 AM
