Adaptor Bushing in a Bosch Colt - Router Forums
post #1 of 3 (permalink) Old 06-23-2017, 02:45 PM Thread Starter
First Name: David
Default Adaptor Bushing in a Bosch Colt
Is there some trick to removing a bit from an adaptor bushing?? I recently used a 1/4" - 1/8" (MLCS) adaptor bushing with 1/8" (straight and dovetail) bits for the first time. I started with the straight bit and could not get it out of the bushing when I finished routing. I finally forced the bit out, put the dovetail bit in the collet and tightened the collet. I removed the adaptor without running the router and found that tightening the collet had frozen the dovetail bit in the bushing. After a couple cut fingers I eventually forced the dovetail bit out of the bushing.
harpone is offline
post #2 of 3 (permalink) Old 06-23-2017, 03:12 PM
are trying to use burrs or Dremel bits in your Colt...
Stick486 is offline
post #3 of 3 (permalink) Old 06-23-2017, 04:29 PM Thread Starter
First Name: David
I was using 1/8" bits that are part of MLCS Pins and Tails Through Mini Dovetail Template kit.
harpone is offline
Bosch Colt on a Full Size Table Question JHZR2 Table-mounted Routing 5 12-05-2013 02:32 AM
New Bosch Colt Owner JHZR2 New Member Introductions 5 12-04-2013 12:01 PM
brass guides and Bosch Colt sourdough Guide Bushings and Templates 7 05-01-2010 09:04 PM
Sold: Bosch Colt router with loads of accessories **SOLD** Bob N Woodworking Classifieds 1 06-23-2009 08:12 PM
template guides for Bosch Colt RuggerJoe Guide Bushings and Templates 13 02-10-2009 09:41 AM
