How to Route a Large Curve - Router Forums
 4Likes
  • 4 Post By Stick486
post #1 of 8 (permalink) Old 11-21-2017, 11:53 PM Thread Starter
Default How to Route a Large Curve
Hi,
I am building a crib for my daughter, which includes a large curved piece for the "headboard" which requires an edge treatment. I have found the following bit: toolstoday.com/classical-cove-bead-router-bits.html (Timberline 400-20) which I think will do the trick although I would prefer something bigger (open to any suggestions).
My question is about the procedure of routing the edge on the curved piece. I think I can do this similarly as I would on a straight run by letting the router base follow the curve. I have included a few screen shots from the model CAD model for the project. One contains some a representation of what i described above using some red marks. The triangle is intended to represent the router bit the line directly above the triangle is the router base and the line perpendicular the workpiece is mean to represent the router itself.
Will this method work? Can anyone provide an suggestions on how to approach it differently.Thanks for any help.
Name:	Screen Shot 2017-11-21 at 10.24.22 PM.png
Name:	Screen Shot 2017-11-21 at 10.27.36 PM.png
Name:	Screen Shot 2017-11-21 at 10.41.00 PM.jpg
Bshmstr is offline
post #2 of 8 (permalink) Old 11-22-2017, 12:19 AM
route from the edge and not the top...
Stick486 is offline
post #3 of 8 (permalink) Old 11-22-2017, 06:34 AM
kp91's Avatar
First Name: Doug
Template guidel bushings
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #4 of 8 (permalink) Old 11-22-2017, 07:58 AM
difalkner's Avatar
First Name: David
Ditto what Stick said; that'll work just fine.
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #5 of 8 (permalink) Old 11-22-2017, 09:31 AM
Honored Member
harrysin's Avatar
First Name: Harry
I would have thought that a bearing bit similar to this one shown would be the simple way. Whilst this one is 1/2", it would be easier using a trim router and they usually only take 1/4" bits.
Harry
harrysin is offline
post #6 of 8 (permalink) Old 11-22-2017, 09:32 AM
First Name: Scott
I agree. you can also use a 1-1/2" template guide and make your template 1/2" smaller.
I've written a book on this, check it out here. https://imaginegrove.com/
scottgrove is offline
post #7 of 8 (permalink) Old 11-23-2017, 06:31 AM
Honored Member
harrysin's Avatar
First Name: Harry
Could you post a sketch showing how you would use a template for this particular job. I'm 100% in favour of templates, in fact there are dozens of my threads showing the making and use of templates in addition to several tutorials but I can't visualise the use of one in this case.
Harry
harrysin is offline
post #8 of 8 (permalink) Old 11-24-2017, 06:12 PM Thread Starter
Thanks for everyones responses so far.
In regards to Stick's suggestion of routing on the side not the top, I guess the advantage of this would be that the bearing on the bit would be riding on the curve instead of the baseplate of the router and the bearing would be able to follow the curvature better.
I like this idea, but I think it would create a different profile on the edge than the one I posted above. The way I'm visualizing it it would basically be inverted, which might be fine.
Bshmstr is offline
Laying Out Large Radius Curves craigwbryant Tools and Woodworking 36 06-28-2016 05:15 PM
Fixture for a large radius curve mcpowell Jigs and Fixtures 16 05-14-2014 07:21 PM
large radial baseboards lmikekelly Table-mounted Routing 4 04-11-2011 01:03 AM
best way to route a frame style edging? sf_basilix General Routing 6 02-11-2010 07:30 AM
