Need to buy a trim router, but not sure which to buy - Page 2 - Router Forums
 4Likes
post #11 of 14 (permalink) Old 01-05-2018, 02:06 AM
First Name: lee
I bought a Bosch Colt for my kitchen remodel since I needed a small trim router. I checked craigslist and bought a Bosch Colt for $50 which looked brand new. It did the job but I am novice when it comes to routers.
coxhaus is offline
post #12 of 14 (permalink) Old 01-05-2018, 08:47 AM
TwoSkies57's Avatar
@FlyingSawdust
Hey Jose..welcome to the community...
I have both the Bosch Colt and the Dewalt 611PK. Both with most of the common accessories. Both have worked out exceptionally well. Well enough that if/when one craps out, I'll replace it with another. The only issues I've had after several years of use are that the collet on the Colt just flat out broke a couple days after I got it and one of the LED's in the 611 crapped out in short order as well. The collet was easily and quickly replaced and the LED is still out *L*...not really worried about it. ZERO problems with either unit since.
The fixed base for both IMHO takes some getting used to because of the small footprint. Very different from the larger traditional round bases found on larger routers. With safe practices and controlled use, both fixed bases work just fine and get the job done nicely. For some the big opening to the bit window on the base of the Colt might be a bit scary but certainly not a deal breaker. You just have to get used to it. I like both of the plunge bases. Both adjust easily, hold their settings and provide a stable platform to work off of. Really don't have a favorite in terms of how the plunge base feels in my hands in use. I don't use dust collection on either router. I should, but I dont.
The Colt is used primarily for smaller tasks and softer woods while I keep the 611PK for medium sized tasks and harder woods. By doing this, I don't work either to death. Dont get me wrong, the Colt can/has handled larger tasks on harder woods quite well, but since I"m fortunate enough to have both routers, I just kinda break up the work load between the two hoping to prolong the working lifespan of each.
If I had to choose one over the other, I'd go with the 611PK only because it can serve as a more general purpose router for the shop/home.
Arcola60 likes this.
Skipper the Penguin
TwoSkies57 is offline
post #13 of 14 (permalink) Old 01-05-2018, 09:00 AM
First Name: Ellery
Very well said, Bill.
I'm exactly where you are on that one. I enjoy using both of those routers.
Arcola60 is offline
post #14 of 14 (permalink) Old 01-05-2018, 10:52 AM
I'd read about the collet issue with the Colt so I bought a couple of extra just in case. So far no problem and I've had it for a couple of years now.
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 07:43 PM
Looking at a trim router IC31 Portable Routing 18 02-16-2013 02:14 PM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 10:20 PM
Should I buy a new router..... tpyke Table-mounted Routing 3 11-19-2007 09:03 PM
