Spice Rack 611 - Page 2 - Router Forums
 25Likes
post #11 of 24 (permalink) Old 02-14-2018, 05:54 PM
Originally Posted by Semipro View Post
First i think you need to start over, but it possible.
A pattern bit with double bearings top and bottom then replace the bottom bearing with a 1/16” smaller bearing. Lay a board acrossed the the cabinet to run the the top bearing on. Now the problem like Mike said your need a router to accept a 1/2” shank bit. Also that bit is Probably over $30
John..
a 1/16'' smaller bearing will only give a 32nd of an inch of cut...
Crossvine likes this.
post #12 of 24 (permalink) Old 02-14-2018, 06:33 PM Thread Starter
Thank you Mr. Stick. Amazon has that bit in stock!
Crossvine is offline
post #13 of 24 (permalink) Old 02-14-2018, 06:50 PM
what about the bearing???
post #14 of 24 (permalink) Old 02-14-2018, 06:57 PM Thread Starter
They have them at the big box store. When I get the bit I'll take it with me to the store so I can see everything.
post #15 of 24 (permalink) Old 02-14-2018, 07:04 PM
they do???
post #16 of 24 (permalink) Old 02-14-2018, 07:12 PM Thread Starter
That's what the kid told me who tried to sell me a set of bits.
post #17 of 24 (permalink) Old 02-14-2018, 07:27 PM
First Name: Richard
Don’t bet on it.
Shop guy is offline
post #18 of 24 (permalink) Old 02-14-2018, 07:29 PM
seek out the Freud bearings...
Danman1957 and Crossvine like this.
post #19 of 24 (permalink) Old 02-14-2018, 07:55 PM
vchiarelli's Avatar
First Name: Vince
@Crossvine - you only need to remove a little over 1/16" on the bottom of each shelf. Rather than finding a bit, setting up a proper support for the router, I'd be tempted to use a ROS (random orbit sander) to remove some material. You don't have to go the full 2 inches on each shelf. Might be a lot easier, less costly.
vchiarelli is offline
post #20 of 24 (permalink) Old 02-14-2018, 11:51 PM
mimac's Avatar
First Name: Brian
If you have plastic lids on the bottles sand them down. You're going to beat up the sides of your cabinet. Maybe try a cabinet scraper or just make a new cabinet. The cost of the wood would probably be less than the price of a new bit and bearings and you would get some satisfaction and experience doing it, plus you would have 2 spice racks, maybe gift the undersized one.
mimac is online now
Spice Rack N'awlins77 Show N' Tell 14 08-26-2016 10:05 PM
Sliding Spice Rack joeboxer JoeBoxer's Gallery 14 09-26-2011 11:01 PM
Greg's spice rack xplorx4 Show N' Tell 46 02-04-2010 03:45 AM
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 11:40 PM
