Spice Rack 611 - Page 3 - Router Forums
 25Likes
post #21 of 24 (permalink) Old 02-15-2018, 12:07 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
I dont think even a skilled carpenter would be able to do that with the shelves in place and get a good finish.
I would go back to the friend, grovel and apologise for your screw up (one of your jars in one hand and a large bottle of his favourite spirits the other) and ask him nicely to start over.
The wood was scrap to start with, so its only his time that was wasted.
sunnybob is offline
post #22 of 24 (permalink) Old 02-15-2018, 09:59 AM
How about setting up a rabbeting bit to cut 1/4" (maybe 3/16" would be enough if the correct bearing could be found) and use it to cut a relief across the bottom of the shelves. You would need some type of support to set in between the shelves to support the router at the edge of the shelf, and probably a stop at each end to control the width of the cut. That would give you 1/2" depth of cut after a couple or more passes. At that point, you could see if the bit could be hung further out of the collet and take more passes - or switch over to a top-bearing pattern bit (most 1/4" shank bits seem to have 1" cutting length although that might be too long) and use the recess already cut by the rabbeting bit to guide the bit until you get to the depth needed. One thing to take into account - you say that the shelves are attached by nails through the sides, need to be careful on the width of the recess to make sure that the bit doesn't hit a nail. As previously recommended, some sincere groveling may be the best approach.
Crossvine likes this.
tomp913 is offline
post #23 of 24 (permalink) Old 02-15-2018, 10:04 AM
First Name: Gary
This is where a Board Stretcher is needed! Ugh.
gmercer_48083 is offline
post #24 of 24 (permalink) Old 02-15-2018, 06:16 PM
seek out the Freud bearings...
CMT for bearings is a good bet too...
this is essentially what you are going to be doing..
Stick486 is offline
Spice Rack N'awlins77 Show N' Tell 14 08-26-2016 10:05 PM
Sliding Spice Rack joeboxer JoeBoxer's Gallery 14 09-26-2011 11:01 PM
Greg's spice rack xplorx4 Show N' Tell 46 02-04-2010 03:45 AM
Built in book shelf/ Shopnotes Clamp rack fasttruck860 Show N' Tell 14 09-25-2009 11:40 PM
