Plunge Router Suggestions - Page 2 - Router Forums
 19Likes
post #11 of 56 (permalink) Old 02-16-2018, 12:54 PM
MT Stringer's Avatar
I have a Triton 3 1/4hp router. It is heavy. The shipping weight of the carton is 16 pounds. Subtract a couple of pounds for packaging, rail guide, and wrench, and it is still heavy. Just sayin'
Mounted in the router table, it works great.
I have used it for surfacing a board larger than my planer and it worked just fine. Still heavy, though.
Name:	2017-04-13 13.04.26.jpg
Name:	2017-04-13 13.04.59.jpg
MT Stringer is offline
post #12 of 56 (permalink) Old 02-16-2018, 01:42 PM Thread Starter
First Name: Ravin
Thanks everyone for the feedback and suggestions. I have not really been doing much woodworking until recently and most of my needs to date have been met by the Harborfreight 2-1/2 HP router. It also weighs around 16lbs and I've done a fair bit of portable routing with it so I'm familiar with how it feels to handle a router that kind of weight. However for plunging the mechanism is really horrible and really won't do for any kind of precision work. To be fair I originally bought it to make some profiles for molds for forming decorative concrete blocks which did not require much precision. But it's time to move to a decent tool.
My reasoning for getting something in the 3+HP range was to have something powerful enough to do things like cutting mortises and through mortises and to have the extra power as needed. I do understand the downsides about weight.
I will take a look at all of the suggested models. Yes it would be nice to walk in somewhere and actually get to hold and play around with the plunge mechanism to see what feels good. Not sure there is such a place around here but I will investigate.
blue_can is offline
post #13 of 56 (permalink) Old 02-16-2018, 04:12 PM
Ravin; where's "here"? There maybe other members with a recommendation as to where you can get your hands on one. A lot of lumberyards will host a specific Manufacturers' Open House, where you can actually try stuff out.
Check out the Manufacturers you might be interested in to see if they show a date on their website.
(I just checked and couldn't find a calendar at Bosch; I e-mailed for more info.)
DaninVan is online now
post #14 of 56 (permalink) Old 02-16-2018, 04:35 PM Thread Starter
First Name: Ravin
Dan - I'm in San Diego, California. There is a Rockler not too far from me - I do go in from time to time to buy stuff - they may have something for me to look at but I think I only see larger tools on display. Also I can check with the two lumber yards I go to go get lumber if they have any open days coming up. I will also check with the manufacturer websites - thanks for the suggestion.
DaninVan likes this.
blue_can is offline
post #15 of 56 (permalink) Old 02-16-2018, 04:47 PM
My local Rockler carries the Bosch line of routers.
post #16 of 56 (permalink) Old 02-16-2018, 04:53 PM
First Name: Eric
Originally Posted by CharleyL View Post
I used a 3 1/2 hp router hand held ONCE!!! Since then I use 2 1/4 hp and smaller routers hand held. 3 hp and larger routers are too heavy and to large to be using hand held.
I think maybe you should get the Bullworker out, Charley. A lot of carpenters use large "3-1/2HP" (in my terms 1800 to 2300 watt) plunge routers precisely because they have enough depth of plunge and the power to back it up on jobs like mortising, cutting post-formed worktop (counter top) mason's mitre joints, cutting housings (dados), etc - all tasks for which a fixed base router is either inconvenient or just plain dangerous. If you use them because you need them then you learn to live with them, although the medium sized (1200 to 1600 watt) plungers are admittedly a lot lighter on my old arms (and therefore more pleasant to use), especially when doing one of those "catch-up" jobs where someone needs to spend 4 or 5 hours routing stuff, The downside is that have a lot less grunt and they lack the depth of cut (often 50 to 55mm as opposed to 70 to 80mm of the heavyweights), As with everything there are compromises.
Overall these days I tend to be doing less heavy carpentry so the medium-sized router works better for me as a main router although I am lucky enough to have retained my "big hitter" as well for the onegtime in 20 that I need loads of power. At the risk of almost blaspheming, I've tried the American-style separate motor and base routers (for example I have a Bosch 1618evs with a plunge base) and in plunge form that router is just big, heavy and bulky in comparison to a purpose-made plunger of similar performance. The table option has far less influence on me because of the sort of work I do, and I'm less than convinced by the low centre of gravity argument some folk use when defending their choice of a fixed base router
harrysin likes this.
"The person who never made a mistake, never made anything" - Albert Einstein
"I too will something make, And joy in the making" - Robert Bridges, 1844~1930
Job and Knock is offline
post #17 of 56 (permalink) Old 02-16-2018, 04:54 PM
I have both a M12V and the V2 as well as a VC. I've looked at the VE and I think they went back towards the V model with that design. I don't know everything it's capable of but the throat opening on the V is smaller than the V2 and it looks like the VE is the same as the V. The V2 came with unscrewable plugs in the plunge columns to make it easy to remove the springs for table use. The V2 also has above the table adjustment capability. You take the phenolic base plate off and there is a 14mm nut that you can put a socket on and turn the adjusting screw with. The V didn't have that option. The V2 was really designed as a table router but wasn't advertised as one.
blue_can likes this.
post #18 of 56 (permalink) Old 02-16-2018, 04:58 PM
TWheels's Avatar
in that case you want a Bosch 1619..
From everything I can find, the Bosch 1619 has been discontinued and there is no new model to replace it.
I Want to Be the Person My Poodles Thought I Am
The RouterForums member formerly known as mftha or th-alton
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
TWheels is offline
post #19 of 56 (permalink) Old 02-16-2018, 05:38 PM
it's fact..
this grieves me...
per Bosch CS...
TWheels likes this.
post #20 of 56 (permalink) Old 02-16-2018, 07:16 PM
Maybe some really good deals out there on remaining stock? Bosch Customer Service will still support it.
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 08:02 PM
Why does a plunge router leave a mark when it plunges into the wood? Duane Bledsoe Portable Routing 37 07-03-2015 02:45 PM
Suggests to set the router for a plunge cut tak35bne General Routing 14 09-04-2014 07:11 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 03:45 AM
