Plunge Router Suggestions - Router Forums
 19Likes
post #1 of 56 (permalink) Old 02-16-2018, 12:54 AM Thread Starter
First Name: Ravin
Default Plunge Router Suggestions
I'm looking for a good plunge router - something in the 3-1/4 to 3-1/2 HP category. Any suggestions on models? I was looking at the Hitachi M12VE - does anyone have any feedback on that?
blue_can is offline
post #2 of 56 (permalink) Old 02-16-2018, 01:54 AM
Semipro's Avatar
First Name: John_*
I have a Hitachi M12VE -it a real workhorse but it is heavy i use mine in my router table
i am real happy with it never had a problem, i installed a muscle chuck on it love that to
Semipro is online now
post #3 of 56 (permalink) Old 02-16-2018, 02:11 AM Thread Starter
First Name: Ravin
Thanks for the feedback. Does it have a smooth plunge mechanism with no side to side play? Since you are using it in a router table I'm guess that is not much of an issue for you.
Also do you know what the difference between the M12VE and M12V2 is - is the M12VE just a newer version of the M12V2.
blue_can is offline
post #4 of 56 (permalink) Old 02-16-2018, 04:55 AM
Originally Posted by blue_can View Post
Thanks for the feedback. Does it have a smooth plunge mechanism with no side to side play? .
in that case you want a Bosch 1619..
DaninVan likes this.
Stick486 is offline
post #5 of 56 (permalink) Old 02-16-2018, 07:10 AM
hawkeye10's Avatar
First Name: Don
Ravin, here is a good place to look and buy routers and other woodworking tools. I and others here on this forum have bought from them. They have very good customer service.
https://www.cpooutlets.com/routers-a...efault,sc.html
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 56 (permalink) Old 02-16-2018, 08:24 AM
DonkeyHody's Avatar
First Name: Andy
Please consider a smaller router for hand-held plunge use. About the only thing a smaller router won't do is spin panel-raising bits. A 3 HP router is just so large and cumbersome and heavy. It's fine to install in a table, but like trying to drive a tack with a sledgehammer to use handheld.
Ray Newman and Semipro like this.
DonkeyHody is offline
post #7 of 56 (permalink) Old 02-16-2018, 08:25 AM
You can't get parts for m12 any more, couldn't get a new starter switch for mine.
You only need four words to have a successful marriage "oh,really,I'm sorry"
curly1 is offline
post #8 of 56 (permalink) Old 02-16-2018, 09:26 AM
Honored Member
harrysin's Avatar
First Name: Harry
You are spot on as regards horse power. The Hitachi is a fine router but I prefer the Makita
RP2301FC, compare the two by plunging with only one finger. In fact, try this test on all the routers that you can find in the shops.
Harry
harrysin is offline
post #9 of 56 (permalink) Old 02-16-2018, 12:05 PM
I agree absolutely on the weight part, Ravin. I have both a Bosch 1619EVS and a 1617EVSPK (finally!), and the size and weight difference is remarkable. I much prefer the lighter 1617.
You're right though; if you're plunging and dadoing with a 3/4" mortising or straight bit in tough wood, you'd certainly notice the difference in power.
Re what you and Stick were talking about re the precise plunge action with the Bosch 1619EVS...mine's been trouble free. Also, if you want to use it in a table you can lock the plunge springs out without having to disassemble anything, not so for other brands.
DaninVan is offline
post #10 of 56 (permalink) Old 02-16-2018, 12:28 PM
CharleyL's Avatar
First Name: Charley
I used a 3 1/2 hp router hand held ONCE!!! Since then I use 2 1/4 hp and smaller routers hand held. 3 hp and larger routers are too heavy and to large to be using hand held. In a router table yes, but a fixed base router is easier to adjust in a router table.
Charley
Central North Carolina
CharleyL is offline
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 08:02 PM
Why does a plunge router leave a mark when it plunges into the wood? Duane Bledsoe Portable Routing 37 07-03-2015 02:45 PM
Suggests to set the router for a plunge cut tak35bne General Routing 14 09-04-2014 07:11 PM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 03:45 AM
