opinions on purchasing a plunge base router. - Page 3 - Router Forums
 19Likes
post #21 of 30 (permalink) Old 03-04-2018, 02:54 PM
Another member mentioned that Bosch was bringing out a new model to replace the now retired 1619EVS...looking forward to seeing the new technology.
DaninVan is offline
post #22 of 30 (permalink) Old 03-04-2018, 03:01 PM
Another member recently pointed out that the MRP23 plunge had the switch in the handle making for awkward and time consuming base switches(?)...
This page snip seems to support that. Never had a 23 in my hands, but the 1617 certainly swaps over very quickly and easily.
The picture below seems not to be the same router style???
Cherryville Chuck likes this.
DaninVan is offline
post #23 of 30 (permalink) Old 03-04-2018, 04:59 PM
Terry Q's Avatar
The MRP23 is no harder to switch over from base to base then anything else. There are two major features that distinguish the 1617 and 23. The electrical connection between the base and motor that allows the switch to be on the handle, with obvious advantages over holding on with one hand and turning the switch on with the other. The other is a light to make it easier to see.
Danman1957 likes this.
Terry Q is offline
post #24 of 30 (permalink) Old 03-04-2018, 05:14 PM
So, how is the electrical carried from the motor to the handle? I can't see any cabling in the picture I included?
As I said in my comment, another member had complained about that issue...I agree, having the switch on the motor of the 1617 isn't as ergonomically desirable (my vote would go to a handle switch).
DaninVan is offline
post #25 of 30 (permalink) Old 03-04-2018, 05:35 PM
Danman1957's Avatar
Welcome from Montreal Roy.
I think the Bosch or Triton are both good choices.
Dan
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #26 of 30 (permalink) Old 03-04-2018, 10:14 PM
Terry Q's Avatar
There is no cable, an electrical connection is made when the motor is inserted into the base.
DaninVan likes this.
Terry Q is offline
post #27 of 30 (permalink) Old 03-04-2018, 10:17 PM
I have 2 1617s, one kit, the other just the motor which was in a lift. Since then I've put a Triton TRA001 in the table, so I now keep a motor in each base. One other thing I like about the Bosch are all the great quality accessories, including dust collection. What I don't like about the Bosch is the switch on the top edge. I do like the ball handles on the fixed base. I had a foot switch on it when it was in the table. The plunge base handles are nice and beefy. It is odd that you need two adapters to use Porter Cable guide bushings, but they are solid once installed. The Bosch bushings are made of steel, and I'd prefer brass. Bosch bushings work just fine, you just don't have the variety without the adapter. For example, bushings with a short collar for working with thin templates. That's my two bits..
post #28 of 30 (permalink) Old 03-05-2018, 11:12 AM Thread Starter
First Name: Roy
Ok, so I caved in. I was at lowes yesterday and saw they had the bosch 23 series with the plunge base on sale for 284CAD which was less than the bosch 1617 so I picked it up.
Haven’t had time to unbox it yet but looks like ill need to buy all sorts of adaptors to be able to actually work with it.
Thank you all for the tips and information.
Roy Philippsohn is offline
post #29 of 30 (permalink) Old 03-05-2018, 11:22 AM
You mean like the Bosch guide bushing set?
https://www.amazon.ca/Bosch-RA1128-8...BMPRKV945NQMW5
https://www.amazon.ca/Shop-Fox-D3117...BMPRKV945NQMW5
And the edge guide (essential!)
https://www.blackrocktools.com/bosch...180305162038:s
That's a good price, by the way.
DesertRatTom likes this.
DaninVan is offline
post #30 of 30 (permalink) Old 03-05-2018, 12:40 PM
The two adapters needed to use the PC bushings are really cheap, about $12 US. I agree on the the edge guide, which is remarkably robust and not very expensive at all. It can also be used as a circle cutting jig, $31 on Amazon.
Plunge base for Marvel 40 trim router johnskudlarek General Routing 8 11-27-2014 05:12 PM
Plunge vs Fixed Base kstern New Member Introductions 20 03-02-2013 08:21 PM
Milwaukee 5625-20 15 Amp 3-1/2-Horsepower Fixed Base Variable Speed Router Review woodrouterreviewsguy Tool Reviews 1 02-23-2012 11:35 PM
Question about plunge base on Ridgid router Sawatzky General Routing 12 01-02-2011 12:44 AM
