Edge guide for Milwaukee 5616 - Router Forums
 3Likes
post #1 of 14 (permalink) Old 06-22-2018, 11:46 PM Thread Starter
First Name: Lenny
Default Edge guide for Milwaukee 5616
I have the Milwaukee 5616 and purchased the plunge base separately. I haven't been able to found an edge guide for it. Are there any available that would be compatible? PC maybe?
toolmanlh is offline
post #2 of 14 (permalink) Old 06-23-2018, 01:01 AM
First Name: Reuel
Default Use the base as guide
Hello
You do not really need to stress too much if you cannot find an edge guide YET. Take your time.
In the mean time use other options:-
1. Use the base of the plunge router guided along one or two clamped straight edge(s). Even better (more fool-proof) than an edge guide.
2. You can also use a 30mm Guide Bush + a 30.2mm slotted jigs as guide.
3. You can make yourself an edge guide. Just get two fitting precision steel rods + some plywood bolts and nuts.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #3 of 14 (permalink) Old 06-23-2018, 09:18 AM Thread Starter
First Name: Lenny
Thanks Reuel. I have been getting by fine for years without it but there are a few times where a guide, preferably with a fine adjustment feature, would be helpful. Heck, my 1975 Craftsman had a nice edge guide with precise adjustment. I know I could make up something (and I may do just that) but I thought I saw somewhere that one of the Porter Cable edge guides had adjustable rods for use with a variety of routers. Can anyone confirm that?
post #4 of 14 (permalink) Old 06-23-2018, 11:39 AM
What accommodation for the guide rods does the Milwaukee have, Lenny?
(Assuming it does have...)
DaninVan is offline
post #5 of 14 (permalink) Old 06-23-2018, 11:59 AM
Check out post #47 in this thread where I made a second guide to attach to an original OEM for one of my routers. I made it for making a groove down the length of a board where the second guide edge would prevent the router wandering away from the board.
The same idea would work to make your own guide edge, all you need are the metal rods to use for the rods that come on the OEM one. Those mild steel rods at the local hardware would work or maybe some drill rod from an industrial supply.
That thread it's in is a very good one with lots of tricks and tips in it.
post #6 of 14 (permalink) Old 06-23-2018, 12:18 PM
You probably already read this article, Lenny?
https://www.asiteaboutnothing.net/g_...outer-jig.html
toolmanlh likes this.
DaninVan is offline
post #7 of 14 (permalink) Old 06-23-2018, 07:32 PM
mjadams61's Avatar
First Name: Marlin
Check this link it may help you.
Milwaukee 5616-24 Router and Porter-Cable 42690 Edge Guide
Now a while back and I wish I knew where on the internet a woodworker got some steel rods and a piece of angle iron and made is own adjustable guide for his.
mjadams61 is offline
post #8 of 14 (permalink) Old 06-23-2018, 10:51 PM
JOAT's Avatar
First Name: Theo
Don't need the internet. Go to a hardware store and they should have just what you want. I know my local hardware has such. Have seen such in Lowes also. I don't do Home Despot, so don't what, if anything they have - I know the few times I shopped in a couple many years ago, I walked out disappointed - then went to Lowes, and they had just what I needed.
mjadams61 likes this.
JOAT is online now
post #9 of 14 (permalink) Old 06-25-2018, 09:01 AM
CharleyL's Avatar
First Name: Charley
Have you looked at a CRB7 ? It's a multi purpose router guide, circle jig, etc. that will fit any router with shoes in the base to attach an edge guide. My CRB7 gets used quite often when I need an edge guide, but it can do many things beside being a good edge guide.
Charley
Central North Carolina
CharleyL is offline
post #10 of 14 (permalink) Old 06-25-2018, 07:30 PM Thread Starter
First Name: Lenny
Awhile back I did go to the hardware store and purchased a rod the correct diameter with the idea I would make my own. But that was well over a year ago and I just haven't found the time yet. Thanks again for the replies.
Hand Routing With An Edge Guide JIMMIEM Portable Routing 13 11-13-2016 11:06 AM
Edge Guide trapped workpiece? PHILRAY1957 New Member Introductions 11 07-19-2016 04:14 PM
Edge guide iredvette General Routing 6 12-18-2014 10:09 AM
Router edge guide purchase imminent. Sominus General Routing 3 01-28-2014 01:16 PM
Rockler Router Edge Guide reds_21 Jigs and Fixtures 1 02-06-2005 11:25 PM
