cutter bearing Festool OFK 500 Q - Router Forums
post #1 of 3 (permalink) Old 07-10-2018, 10:28 PM Thread Starter
First Name: Peter
Default cutter bearing Festool OFK 500 Q
Hi
may I ask anyone who owns the above, what is the NMB number of the bearing to be used for the FIRST original cutters which had a large screw coming from the cutter to hold it to the armature?
regards
Peteroo
Peteroo1 is offline
post #2 of 3 (permalink) Old 07-11-2018, 08:51 AM
First Name: Gary
Description Lacking...are you asking about armature bearing, or a cutter bearing?
gmercer_48083 is offline
post #3 of 3 (permalink) Old 06-02-2020, 11:28 PM
It is the part of numbering system.
AbbieAbbott is offline
Flush Trim Cutter with Down Shear - Bottom Bearing John Charnock General Routing 14 05-04-2017 10:53 AM
Router cutter bearing problems JeremyB Starting Off 6 06-10-2014 06:36 AM
Stackable Slot Cutter with top bearing? JDSW Portable Routing 4 06-03-2014 06:46 PM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 01:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 11:44 AM
