Festool OFK500Q cutter bearing - Router Forums
post #1 of 3 (permalink) Old 07-13-2018, 10:25 PM Thread Starter
First Name: Peter
Default Festool OFK500Q cutter bearing
Hi
may I ask anyone who owns the above, what is the NMB number of the bearing to be used for the FIRST original cutters which had a large FLAT screw coming from the CUTTER bearing to hold the cutter to the armature?
regards
Peteroo
Peteroo1 is offline
post #2 of 3 (permalink) Old 07-14-2018, 10:20 AM
First Name: Gary
A photo of what you are describing might help someone see what you are looking for.
gmercer_48083 is offline
post #3 of 3 (permalink) Old 07-14-2018, 12:13 PM
Many different brands of router bit bearings interchange. You just need ones with the right I.D.
cutter bearing Festool OFK 500 Q Peteroo1 Portable Routing 1 07-11-2018 09:51 AM
Router cutter bearing problems JeremyB Starting Off 6 06-10-2014 07:36 AM
Stackable Slot Cutter with top bearing? JDSW Portable Routing 4 06-03-2014 07:46 PM
Profile Cutting Cutters and their Bearings neville9999 Jigs and Fixtures 7 12-10-2012 02:11 PM
The use of a Router table as a Profile Copier neville9999 Jigs and Fixtures 4 12-06-2012 12:44 PM
