Router Ski Panel Flattening Question - Page 2 - Router Forums
 23Likes
post #11 of 13 (permalink) Old 09-13-2018, 11:41 AM
Originally Posted by Herb Stoops View Post
I do it like Don said . Only I saw it all the way through and joint the edge and re glue it. Then if it needs more in a different spot I do it again til it lays flat, the grain matches so the saw cut don't show. Some times I rip them and turn them end for end. Then after they are glued up I run them through the planer or drum sander to finish them. I find that less thickness is lost by doing this.
Herb; if you flip end for end don't you create an issue with grain direction when it comes to the planing? Why not just flip the piece over top to bottom, assuming the quality is the same for both sides (no knots etc.)?
You'd also counter the warp effect by flipping over.
DaninVan is offline
post #12 of 13 (permalink) Old 09-13-2018, 12:20 PM
Your suggestion sounds good to me. If I flip end to end,I dress it down with the drum sander. That is the last resort because when the finish goes on the grain reflects the finish dark and light.
I can flatten most boards by just ripping and reglueing as many times as it takes.
One time I had a PU load of reject Elm 1" rough sawn boards from the mill given to me. They were straight on the edges but the hump was between the ends ,like skis. I ended up ripping them into 2 1/2" wide strips and then planing them. and nestling them (spooning them) together making a 2 1/2" thick plank ,then resawing them into (2) 1" thick boards.
DaninVan likes this.
Herb Stoops is online now
post #13 of 13 (permalink) Old 09-13-2018, 07:46 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Originally Posted by Bushwhacker View Post
So many different ideas, some more drastic then others, but what ever method you choose, My first knee jerk thought was the Concave down and the Convex up, seems to me that would lessen any rocking or need to shim it. Then flip it. But as Herb said, you would lose a lot of material in thickness that way. I never would have thought of his idea of splitting it and reglueing Please be careful and post your results . I for one would like to see how you do it and what the out come is.
David
I am missing Stick´s reply.
We, woodworkers are everywhere!!!
papasombre is offline
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Question Upgrade Fence or Router ronheb454 Table-mounted Routing 9 07-30-2013 01:15 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 09:47 AM
