Router Ski Panel Flattening Question - Router Forums
 23Likes
post #1 of 13 (permalink) Old 09-12-2018, 07:46 AM Thread Starter
Contributor of the Month
Default Router Ski Panel Flattening Question
I have a glued-up panel (Red Oak 22" X 22" X 3/4") that has a slight amount of cupping. I recently made Harry-Sin-Style Router Skis and would like to use them to flatten the panel. Which side gets flattened first, the concave or convex side?
JIMMIEM is offline
post #2 of 13 (permalink) Old 09-12-2018, 08:56 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Its easier to get the concave side flat to the base than the convex side.
Bear in mind youre going to lose a heck of a lot of thickness by the time you get both sides parallel again. i think it could be as much as half the board thickness.
Might be better to just flatten the side thats going to show.
sunnybob is offline
post #3 of 13 (permalink) Old 09-12-2018, 09:07 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Without doubt the CONVEX side first because the CONCAVE side will sit flat on the bench, whereas the other way it will rock like a cradle.
Harry
harrysin is offline
post #4 of 13 (permalink) Old 09-12-2018, 10:49 AM
The same orientation holds true if you were running it over a table saw, jointer, or planer for the reason Harry gave. In fact, cutting on the TS with the convex side down can be really dangerous as it can cause the blade to bind and toss the work piece.
post #5 of 13 (permalink) Old 09-12-2018, 11:45 AM
hawkeye10's Avatar
First Name: Don
Have you thought about using your table saw to flatten the board? Put the convex side down on the TS and saw a groove about 2/3 through the board. After that put some glue in the groove and clamp it down on a flat service. It should come out after the glue dries pretty flat.
You might have to shim the board on either side to keep it from rocking while sawing. You could use double stick tape to attach the shims. If you decide to do it let me know how it came out.
Gene Howe likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #6 of 13 (permalink) Old 09-12-2018, 12:08 PM
Gene Howe's Avatar
First Name: Gene
My router/planer jig sees a lot of action. But, if the work fits in the planer, I use a sled and shims/wedges. It's faster.
I've used Don's method to straighten 2X4s. But, I use a skil saw and several cuts. It ain't purty but, if it's going to be sheeted, as in shop doors, it don't show.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #7 of 13 (permalink) Old 09-12-2018, 03:34 PM
This accident was an early experience with my first table saw. Hit me in the solar plexis and the bruise and pain lasted for months.
If it isn't flat, I don't put it on the table saw, not anymore.
DesertRatTom is online now
post #8 of 13 (permalink) Old 09-12-2018, 06:01 PM
I do it like Don said . Only I saw it all the way through and joint the edge and re glue it. Then if it needs more in a different spot I do it again til it lays flat, the grain matches so the saw cut don't show. Some times I rip them and turn them end for end. Then after they are glued up I run them through the planer or drum sander to finish them. I find that less thickness is lost by doing this.
Herb Stoops is online now
post #9 of 13 (permalink) Old 09-13-2018, 08:57 AM
Bushwhacker's Avatar
First Name: David
So many different ideas, some more drastic then others, but what ever method you choose, My first knee jerk thought was the Concave down and the Convex up, seems to me that would lessen any rocking or need to shim it. Then flip it. But as Herb said, you would lose a lot of material in thickness that way. I never would have thought of his idea of splitting it and reglueing Please be careful and post your results . I for one would like to see how you do it and what the out come is.
David
When the enemy is in range, so are you.
Bushwhacker is offline
post #10 of 13 (permalink) Old 09-13-2018, 09:07 AM
harrysin's Avatar
First Name: Harry
There are times when the table saw is the only answer.
Harry
harrysin is offline
Getting Started With A Woodworking Router. learnexperience Table-mounted Routing 9 10-22-2014 06:43 PM
Question Upgrade Fence or Router ronheb454 Table-mounted Routing 9 07-30-2013 01:15 AM
Using Your Router For The First Time learnexperience General Routing 0 07-23-2011 09:20 PM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 09:47 AM
