Bosch Gof 1600 ce - Router Forums
post #1 of 2 (permalink) Old 12-19-2018, 09:16 PM Thread Starter
First Name: Peter
Default Bosch Gof 1600 ce
Hi
may I ask what is the best way to collect the dust from edge forming with the above router?
Thanking you in anticipation
regards
Peteroo
Peteroo1 is offline
post #2 of 2 (permalink) Old 12-20-2018, 03:11 AM
Bosch sells some dust extraction attachments for some of their routers like this one: https://www.ebay.com/itm/Bosch-3pc-D...TxJ:rk:14:pf:0
One from Oneida: https://www.amazon.com/ONEIDA-SYSTEM...tor+base+plate
And this one from Rockler: https://www.amazon.com/Edge-Routing-...tor+base+plate
All of those are for hand held edge routing. If you meant on a table then use a fence mounted pickup or make a fence like I did that has a box built around the bit which a vac hose fits into.
Bosch GOF 1600 CE Won't Start sammarkowitz General Routing 16 10-13-2016 02:42 AM
Bosch GOF 1600 (stuck) collet/shaft/lock button problem? Tribute General Routing 13 01-11-2016 10:27 AM
Bosch GOF 1600 CE AllanG Tools and Woodworking 1 08-24-2014 11:28 PM
Bosch GOF 1600 CE router Peteroo Jigs and Fixtures 1 01-19-2014 09:39 PM
Bosch GOF 1300 ACE Spares JanP General Routing 9 01-26-2013 05:39 AM
