Adding LED lights to a router - Page 2 - Router Forums
 34Likes
post #11 of 20 (permalink) Old 01-02-2019, 07:49 PM
First Name: martin
I found that amber color LEDs give you the best viewing, they cut through all the background lighting, and really stand out. routers that have built in led lights have a tap on the field winding, as well as a rectifier and a resistor, so, it's a bit involved to add one that is built in..
graeme.c.payne likes this.
radios is offline
post #12 of 20 (permalink) Old 01-02-2019, 09:23 PM
Amazing, isn't it Harry, how you can still have an impact on younger people even though you can't do the shop stuff yourself any longer. Way to go Harry!
harrysin, Belg and MEBCWD like this.
DesertRatTom is online now
post #13 of 20 (permalink) Old 01-02-2019, 10:15 PM
First Name: Harry
I picked up a cheap 15" LED strip from Banggood and mounted it on the bottom of the gantry of my CNC. Even added a dimmer, bright fr setup and dimmer while routing
kp91, harrysin, MEBCWD and 1 others like this.
htasker is offline
post #14 of 20 (permalink) Old 01-06-2019, 12:28 PM
RainMan 2.0's Avatar
Wow is that ever a great idea ! I can see that catching on in a hurry
Ok ,I never insulate
RainMan 2.0 is offline
post #15 of 20 (permalink) Old 05-25-2019, 10:41 AM
LeftFinger's Avatar
First Name: Rich
My first router was a craftsman in 1975 It had a bolt on flashlight as an attachment , worked until a chip hit the lens
LeftFinger is offline
post #16 of 20 (permalink) Old 05-25-2019, 11:34 AM
You might find this site useful as a source for parts. https://www.superbrightleds.com/?msc...ontent=General
I think I'd start with a power supply meant for an LED light of some sort. We used to call it full wave rectified--a steady stream of direct current. A half wave unit will just cause filckering. You can find raw LEDs in a variety of places. They have raw wire leads you'd have to insulate if you just attached the LEDs to the inside of the base, so you'd want to lay a coat of plastic to where the wires would connect as insulation, or use some fine heat shrink wrap to insulate. I think you could tape the wire from the power supply to the LED to the router's power cord. Rockler has some non adhesive wrap that might do for this, but I wouldn't use standard duct tape with its gooey adhesive. For occasional use, a battery would be easier, but not for constant use.
The idea to me is to integrate the LEDs with the base with the least bulk you can, that means raw LEDs glued in place with epoxy, to me.
post #17 of 20 (permalink) Old 05-25-2019, 06:45 PM
Gene Howe's Avatar
First Name: Gene
Sign carvers like this one from Amazon.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #18 of 20 (permalink) Old 05-26-2019, 10:37 AM
Honored Member
harrysin's Avatar
First Name: Harry
This low cost one from, I think K Mart some years ago was very useful.
Harry
harrysin is online now
post #19 of 20 (permalink) Old 05-27-2019, 11:10 AM
tulowd's Avatar
First Name: Paul
just a Public Service Announcement from a guy in the lighting field.
If you have a choice of color temperatures, the highest perceived illumination for the human eye will come from 4000-6500 K temperature LEDs. That's why parking garages use 5000k color that isn't very pretty, but they meet code requirements for foot candles while keeping power consumption to a minimum. Contrast is what the human eye needs in order to see details. Think about newspapers and how in bright environments you may not need reading glasses.
4000k is a typical commercial color used in offices etc, altho a lot of that is changing. 2700-3000 is what you see in residential kitchens and washrooms. 3500 k is used in most architectural designs.
6500 gives the best pop of colours etc and is what I use to light up my workshop.
If you really have a choice, CRI (color rendering index) is standardized at 80+, some nicer spaces call for 90+ and museums and other high value environments call for even higher numbers. I believe California recently introduced 95CRI requirements for their (new) street lighting. This will eventually be adopted throughout the industry, so everything will end up looking nicer.
Think about how when walking thru Home Depot's lighting section, the glare and harshness has improved every year......along with light levels and efficiencies.
It's a great time to be alive and see all these (new) technologies mature and flourish.......
a 16 year old hooligan stuck in a 55 year old's carcass
tulowd is online now
post #20 of 20 (permalink) Old 05-28-2019, 10:26 AM
Honored Member
harrysin's Avatar
First Name: Harry
6500į also known as illuminate D or TV white is the colour temperature of a pure white TV screen (when set up correctly) .
Harry
TARGET LED lights rework Potowner1 Shop Safety 10 11-28-2016 12:56 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 06:20 PM
Milwaukee 5625-20 15 Amp 3-1/2-Horsepower Fixed Base Variable Speed Router Review woodrouterreviewsguy Tool Reviews 1 02-23-2012 11:35 PM
adding a speed controller to a single speed router Sawatzky Table-mounted Routing 5 01-24-2009 09:49 AM
Old Glossary Terms Mark Site Help and Suggestions 0 10-14-2008 02:30 AM
