Router Misalignment? - Page 2 - Router Forums
 21Likes
post #11 of 26 (permalink) Old 03-28-2020, 01:04 PM
JFPNCM's Avatar
First Name: Jon
Looking at the picture in Stick's post the right edge of the board appears to be rounded, particularly in comparison to the left edge. On looking at the first photo the top edge appears flat and the bottom edge rounded. If correct, that could account for at least add to to difference in two grooves.
Jon
JFPNCM is online now
post #12 of 26 (permalink) Old 03-28-2020, 03:26 PM Thread Starter
First Name: Cole
Hi folks, wow a lot of helpful suggestions from all of you. So kind thank you. I already dismantled the jig piece by piece to try and determine the issue. Basically I sandwiched the stock between two pieces of planed stock as well as the ends and secured them to a planed piece of pine as a base. On the top I also secured an offset piece of planed pine as a guide to slide the router while resting on the workpiece. Probably not the safest as the workpiece was not clamped down 100%
I have a rough drawing of my makeshift jig, please excuse the crude freehand drawing.
The 2 3/8" is the distance between the centre of the Router Collet and the guide on top of the jig which I used as a guide to align with the flat edge of my router to cut the channel .5" while cutting from left to right from the top edge of the stock. Yes there was a bit of play as the flat edge of my router is slightly taller than the top pine guide
Bad idea?
A router attachment may be more suitable as I do not have a table saw unfortunately.
20cCc20 is offline
post #13 of 26 (permalink) Old 03-28-2020, 03:31 PM Thread Starter
First Name: Cole
Here are some pictures of the jig that I took, my apologies again as I reassembled the jig to help illustrate how I assembled this colossal failure in the first place.
Again thank you all for your input, I really appreciate your suggestions.
20cCc20 is offline
post #14 of 26 (permalink) Old 03-28-2020, 03:39 PM
Don't take this as an insult, absolutely not meant that way! Is it possible that you used the flat face of the router base for one side and the curved portion for the other side?
Easy enough to check if the two respective router base faces line up with their respective channels...
Added text: the very last thing I would consider is the router itself. It's new; what could be wrong?
http://www.woodworkingtoolsetc.com/ryobi-router.html
https://www.homedepot.com/p/RYOBI-10...PL1G/205509658
Great price for a plunge base router.
JFPNCM and Nickp like this.
DaninVan is online now
post #15 of 26 (permalink) Old 03-28-2020, 03:46 PM
Nickp's Avatar
First Name: Nick
From the pictures it appears the base of the router does not sit flat on the base in front of your edge guide/fence...this can allow for some tilting when you depress to plunge.
Maybe you can do something about that...not absolutely necessary if you can keep the router base flat on the work piece.
Maybe the router base (flat edge) could be "jumpy" as you route your piece...recommend waxing the face of the fence so it slides easier.
Are you sure the work piece is held in place on all four sides, specifically the edge that faces the fence...this could be the big factor in the distances varying...
Is the plunge action smooth or does it have any rough spots...? Are you using the plunge depth adjustment rod against the turret to make your cuts...?
JFPNCM, roxanne562001 and Stick486 like this.
Nick
Nickp is online now
post #16 of 26 (permalink) Old 03-30-2020, 08:52 PM Thread Starter
First Name: Cole
Hello folks, sorry to seem evasive but below is what I am restoring. It is a bracket to support a table top on a desk,, I kind of need a matching one as the original is in very inoperative shape,, rotted out and discarded actually, so that is what I am working on. Those grooves on the sides are where you attach brackets that fasten the desktop to.
But I may have produced a solution,,,hopefully. Bring the mountain to Mohammed so to speak,,,,
Instead of revisiting the previous failed method that I employed, I built a makeshift sliding jig that I attached to my router, which is a bit safer too because it allows me to clamp the stock down more securely,, and hopefully more accurately.
And Nick thank you,,,,I will wax the bottom of this contraption too before I give it a go.
For now?
Having a cup of coffee,,No joe??? No Go!!!
20cCc20 is offline
post #17 of 26 (permalink) Old 03-30-2020, 09:44 PM
One other thing that can affect what you are doing is feed direction. If you are following a guide that is on the opposite side of the router from you then you should be working from left to right. If it`s between you and the router you should be working from right to left. Going the opposite directions might possibly cause the bit to ride up as you cut and it makes the bit more prone to wander away from the guide strip.
post #18 of 26 (permalink) Old 03-30-2020, 11:00 PM Thread Starter
First Name: Cole
Hello Chuck, thank you for your advice. This makeshift gizmo unlike the last jig I devised will ride on top of the stock from left to right which will be secured in a vice on my bench, sandwiched between two pieces of planed pine, and offset to accommodate the .5" from the top edge. I agree with you on the left to right feed direction, hopefully this will prove to be more accurate than my previous attempt which yielded a most unsatisfactory result. And I like Nicks advice too, waxing the underside of the sled-jig to allow for more fluid feed motion.
Cheers!!!
Wish me luck, gonna give this a go in the am.
Cherryville Chuck likes this.
20cCc20 is offline
post #19 of 26 (permalink) Old 03-30-2020, 11:14 PM
TenGees's Avatar
First Name: Paul
Placement: Is the fence moving?
Depth: Is the collet snug? Does the plate sag? Is the plunge depth lock on? Is the oak straight?
TenGees is offline
post #20 of 26 (permalink) Old 03-31-2020, 12:07 AM Thread Starter
First Name: Cole
Hello Paul , The collet is snug, plate does not sag and yes I usually set and lock the plunge depth edge to edge as opposed to plunging from the top. I did set the oak straight using the piece from my first failed attempt, so in a sense the first piece did not get trashed in vain, it actually allowed for better bit setting. And the stock has a bit more support from both sides, so to answer your first question, yes I suppose this will be a moving fence. What do you think? Good? Not so good? have you tried this before?
20cCc20 is offline
